lawrence
Patron
according to aerox: my aluminum oxygen tank needs a "hydro test" every 5 years. is every body having this done? any trouble getting your tank refilled if "out of date"?............thanks.....
Get it done
I use to do a lot of scuba diving and dive tanks have to be hydro'd every 5 years. Most dive shops would not fill tanks unless they had an annual visual inspection (VIP) and were "in hydro".
This is a safety thing, both for the folks filling the tank, and for YOU.
Dont skip it.
Fire extinguisher service companies are a good source for hydro work, also welding supply stores.
Also, if you have a composite tank, aluminum with an epoxy/filament wrap, most of these have a finite service life.
Mike
It is a DOT requirement. NO ONE will fill a tank that is out of its 5 year cycle. I had mine done at a scuba shop. Typically the scuba shop is less expensive than taking it to an FBO.
Gary
