hcccs
This is my spare Marvel Schebler MA4-SPA carb. I have the same on my RV-4. The plugged hole at "A" is where the carburetor temperature sensor is located. What is the plugged opening at "B" used for?
My manifold pressure sensor is connected to cylinder no 4 but on my previous homebuild with a MA3-SPA it was connected to the carburetor at "A". What is the difference between having MAP sensor connected to the cylinder and the carb?
