I'm going to call Van's tomorrow to confirm but I made a big mistake and I'm hoping I can correct it without redoing both elevators. On the RV-10 elevators, on the rear spar, you dimple the flanges *except* you countersink the inside top flanges because that is where the trim tab hinges will go later.
Well, at some point, I switched my elevator rear spars. Either that, or I countersinked them incorrectly. After riveting one full skin and half of the other, as well as riveting the ribs to the rear spar, I realized I have it wrong. I have the countersinked flanges facing the bottom skin, not the top skin.
My options are:
(1) buy two new skins, two new rear spars, and 16 new flanges and try again
(2) drill out ~32 rivets where the ribs connect to the rear spars, then ~100 rivets where the rear spars attach to the skins, and swap the spars.
(3) Un-dimple the inside holes on the top flanges on both sides, then countersink, and proceed with the build.
Obviously (1) is the cleanest option but costs some money and especially time. For (2) I'm worried about the damage I might cause by drilling out that many rivets. For (3), well I've never un-dimpled and then countersunk so I wanted to see if there was any advice out there if I decide to go that way.
Thanks in advance!
My options are:
Thanks in advance!
