Absolutely do as JRS said. There can be no paint allowed between the spacer plate and cylinder, or under the nut. Only a very thin, max .0005 inch, coat of primer.
I met a rocket owner at Moose Creek Idaho that had lost a cylinder at Johnson Creek years before. Had a 540 narrow deck engine that was likely assembled wrong, blamed a Snap-On torque wrench. When it happens there are no clues except loose cylinder hold down nuts and maybe a little paint left under the spacers.
I lost two cylinders, a year apart, on a “professionally” built IO360 narrow deck engine before realizing this. The paint will fret away with a resulting loss of short stud torque, then unzip all the short studs. Occurs about 500 or so hours after cylinder installation. This is documented in the Sky Ranch Engine Manual.
You must also hold the spacer away from the cylinder with feeler gauges when torquing. This is not so clearly stated in the overhaul manual. Read the whole thing before working on an engine. There are many details, not necessarily in order, in the manual.
George
