Valve Corrosion and guide wear
BruceMe
I boroscoped my engine for annual this weekend and it all looked fine except for one exhaust valve.
I like doing things myself. I have the cylinder wrenches, valve tools, and access to an arbor press, is this something I can do myself? Pull the jug, drop the valve, seat a new valve, and put it all back together?
AMWts8BKuhGE0MUlm6obrgcyuSmWrItpsDPrT81xO8xzbN9hluabIzPgK-VkOuf9w_gSBM_PK3bwHvSU70zWZ6EmbJSI3_ed-mSmTb4HahM44edsw3G6L6svHeR1T_Y0Ro7mD1EeWJK5JFUyW-1kwC25qjxtkg=w1280-h720-s-no
AMWts8BbXPtkQZIZLeMrYDl8fGNanGwy2XzFBxxYCF8StMrg8oE0QefYjy7p8lnStVsiCZhohpEpY3ORZswmO2q4KOx1riOchJvZg4cJk1Pa4mhju6GvhULowjUE029_lLfcEvq8KZCNc0_A7iL_HANl5rxPRQ=w1280-h720-s-no
AMWts8AkJh4TmuNINTBrJqeGtnm8ilBslqNu64ClyRwZydl-Luc5SYOETuBXOwKjNNMV_izMWZvnLVM_D3Q67_sCVMrft2CCEUeAE0eiPo9eCHn7f_yVrLxy7grdzXv6VTHb2ik4vsa9RLoWVdBrqvE03I8OLA=w1280-h720-s-no
Thanks!
How is the leak-down test? It does look like it has been hot, but may just be solved ( arrested) with a new rotator and "grinding" the valve/seat insitu. If that is the case the valve can be pulled through a spark plug hole and stem cleaned.
I am not sure about the details of this specific engine but standard practice is to have a relief up in the guide for the distance of lift to accommodate deposits.
https://www.youtube.com/watch?v=3lA_ZrKoWZ0 This may help visualize.
To your question - - maybe. Are you thinking replacing the valve guide too?
Pull the jug, and take it to a shop that does cylinders for a living.
Minimum is replacing that corroded valve. That should include checking the guide, and replacing as necessary. And, the seat should be ground in the process.
Replacing a guide, and grinding the seat is not something you want to do without the proper tools, fixtures, processes.
Pull the jug, and take it to a shop that does cylinders for living.
+1 for this option. Your phots are fantastic. What borescope do you have?
You will need a valve seat cutter and the appropriate pilot to go in the guide. I do this on my Bridgeport. Clean up valve face on the lathe. If you don't have this equipment handy its easier to have a cylinder shop do the work. Problem is, every shop in the known universe is backlogged.
I plan to do this this summer. Made a pilot for the COTS cutting stones (a copy of the souix pilot) and adapters for int and exh as well as pressing tools to remove the guides. But think a mill is necessary to ream the guides. Might get away with a drill press if you can properly square the table. Also plan to cut the valves on the lathe. Be prepared that you may need to go up a size on the guides and will need to ream accordingly (sold in .005 OD increments).
Are you sure it is corrosion and not deposits? I was under the belief that the Lyc exh valves were stainless.
I will do the rope trick first and pull the stem through the sparkplug and look it over. You may be right.
I wouldn't pull a cylinder based on the pics I see. comps, wobble values, valve rotators check, pics look ok to an untrained eye. :eek:
Generally speaking (writing really…) I’d say that this is a a good example of today’s over information…
Look long enough at anything, and you will always find something wrong, looking suspicious, needing remedy.
In the meantime others just fly :D
Without compression data we don't know the full story.
I've seen many a stem and valve look like this one and not be defective.
I'm sure if compression was up to snuff I'd just fly it.
The pizza looks fine.
Art
