Not so fast Batman
Subpar -
The installed baggage corner skins seem to be a problem.
I installed my torque tubes and drilled same today, but without corner skins installed.
This allowed me to drop the flaps with the wings installed and insert the torque tubes from the inside out without the obstruction of the corner skins.
One solution may be to pull the wings away from the fuse far enough to slip the torque tubes into position from the outside of the fuse. Then push the wings back in place and secure. Then carry on with the balance of the torque tube drilling instructions.
David Grady
RV-12iS #121089
Build in progress. Empennage, Wings, Fuse, Finish Kit done.
N12DG (reserved)
