VAF on Twitter:
@VansAirForceNet
Old 09-05-2022, 02:48 AM
KayS KayS is offline
Default lead-alternative for protecting valve seats
this weekend i stumbled over something at a swiss gas station and the current discussion about G100UL came to mind. here's the stuff...
https://motorex.com/en-us/valve-guard--40918
they sold the bottle for 10 bucks or so. switzerland is not known for being an el cheapo country.
i am no engine expert and have no clue if lubricating valve seats is really needed and if so for what kind of engines that would apply.
but in case you think it's a good idea to lubricate your valve seats and in the future absence of 100LL... does anyone has experiences with that kind of product as an alternative to leaded avgas?
Kay
Old 09-05-2022, 03:38 AM
tgmillso tgmillso is offline
Hi Kay,
Before you part with your hard earned cash, it may pay to read some of John Deakinís articles. Hereís one to get you started, but heís got plenty on engine operation, leaning etc.
https://www.avweb.com/features/pelic...n-the-hogwash/
Tom
RV-7
Old 09-05-2022, 05:34 AM
RV6_flyer's Avatar
Originally Posted by tgmillso View Post
Hi Kay,
Before you part with your hard earned cash, it may pay to read some of John Deakin’s articles. Here’s one to get you started, but he’s got plenty on engine operation, leaning etc.
Tom
RV-7
Tom:
Thanks for sharing.
Those that are old enough to remember lead in our car gas can remember the same scare tactics when TEL was removed from car gas.
Nothing happened to old car engines when we went lead free fuel.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 09-05-2022, 07:48 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Other than you no longer needed to scrape the sludge out of the oil panÖ.
Carl
Old 09-05-2022, 08:31 AM
lr172 lr172 is offline
Tom:
Thanks for sharing.
Those of use that are old enough to remember lead in our car gas can remember the same scare tactics when TEL was removed from car gas.
The auto companies moved to different alloys for valves and seats when lead went away. I speculate that many engines of that era lost compression and either died early than they should have or had the valves replaced. I was barely a teenager, so not yet working on engines.
My guess is that Lyc moved to the then standard alloys for valves and seats in the 80's as the older stuff was probably harder to get.
Larry
Old 09-05-2022, 09:14 AM
blaplante blaplante is offline
At one time auto cylinder heads were cast iron, and the seats were simply machined into the cast iron. THOSE seats depended on lead to survive. Early MGB's are an example.
As the lead went out, hardened steel valve seat inserts went in. [Or were retrofitted, like on my MGB]
As Lycoming heads were never cast iron (but rather aluminum), they always had to have a valve seat insert.
RV6A in phase 2 as of April 2016
Donation made Dec 2022
Old 09-05-2022, 10:49 AM
abwaldal@gmail.com abwaldal@gmail.com is offline
To add on to Blaplante's comment of old valves/heads.
I had an older chev van in the late 80's that we ran on propane. (dumb idea)
We tore the engine down at about 150,000 for overhaul cause of oil burn/leak problems.
The valves were very, very worn and the seats were gone. We actually got a different set of heads and had them machined for steel hardened seat inserts.
Propane is hard on valves. That said, Was it the lack of lead? or just the propane? It was the first time I\'ve ever seen valves worn out like that. And I've overhauled a few thousand of the older motors. A lot of times at only 60-80,000 miles too. They didn't seem to last very long.
Don't know, But, as said we have insert seats in our aircraft engines, So the lead lubrication question seem to be a moot point.
My I0-360 runs on Costco premium year in and year out.
With the SDS EM-5F fuel injection and ignition systems.
My three cents worth Art
Fixit
Old 09-05-2022, 10:59 AM
Roadjunkie1's Avatar
Roadjunkie1 Roadjunkie1 is offline
Default TEL in fuels
Good article, as all of his seem to be.
OK: first off, I really miss the smell of 80/87 octane fuel! For all you younger folks, it had this pretty dark purple color and a very unique odor! 100/130 and eventually 100LL just not the same. And unleaded auto fuel: no competition!
I really can't remember when I started using auto fuel in my Cub but it "might" have been before 1982 when the STC came out. I was one of the first in line to get that STC. Now she flies with the placard allowing for the use of auto fuel....with no alcohol!
I could look at my log books to find out how many hours I have on auto fuel but it is likely over 1500. I have had several stuck valves but Continentals (and to an extent Lycomings) are famous for that. I have replaced one cylinder with an eroded exhaust valve seat but that might have happened with leaded fuel. I do slip 100LL in the tanks occasionally when other fuels are not available (and auto is becoming less frequently carried at airports) and check plugs for fouling at about 25 hours after.
I still run 100LL in my 160hp O-320 RV-4 but am not sure auto would have the octane to prevent detonation. It will be interesting to see where this all ends up. SOMEthing has to happen.......will happen.......
The picture is my younger (and skinnier) self fueling the Cub c 1982 or so....
Click image for larger version
Michael
RV-4 2860 SuzieQ
1946 C-90-8 J-3 Cub
The adventure begins when things stop going as planned - Glen Heggstad
Exempt but still a happy Subscriber! 2022-2023
Plummit's Avatar
Plummit Plummit is offline
Isn't that what MMO is for?
-Marc
RV-10
N814RV
2022 Donation Made
Plus extra donation for someone who didn't
Old 09-05-2022, 01:19 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
-Marc
I was told it was for valve guides, not seats.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
