VAF on Twitter:
@VansAirForceNet
Old 08-02-2022, 06:18 PM
msmst25 msmst25 is offline
Default Trailer Rental for RV-10 Fuselage
It's time for me to move the fuselage out of the garage and into a hangar at Aurora. The wheel base seems a little wide for your average trailer. Does anybody know where I can rent a trailer big enough to accommodate this in the Portland metro area?
Thanks for any suggestions.
Old 08-03-2022, 09:12 AM
lr172 lr172 is offline
climate differences may make this impossible, however, I rented a two place snowmobile trailer that worked great. It is more than wide enough and it tilts for easy on load off load. Not too expensive either.
Larry
Old 08-19-2022, 06:54 PM
Bsquared's Avatar
Bsquared Bsquared is offline
The only trailer I found that was wide enough was going to cost $250-$300 to rent. I ended up finding a flat bed tilt bed tow truck and the driver only charged me $200. It worked great and 3 of us were able to safely load and unload it. I think many folks have used this method for a 14 fuse on it gear. Not sure if the 10 gear is wider
RV-14A
Flying Nov 2020
Old 08-19-2022, 07:18 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Look into trailers for moving heavy equipment.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-19-2022, 07:33 PM
N427EF N427EF is offline
Default Towing company
I doubt you'll find a trailer to rent for less than calling a towing company.
Their trailers are wide enough to accommodate the RV-10 wheel base and loading is easy with their tilt loading deck and winch equipment.
That is what I did and it was a non event.
See post #4 https://vansairforce.net/community/s...d.php?t=152194
Ernst Freitag
RV-8 finished (sold)
RV-10 IO-540 8.5:1
Running on 91 Octane E10 mogas since 2011
We all get what some of us deserve
Old 08-19-2022, 09:43 PM
9GT's Avatar
9GT 9GT is offline
A large roll back flatbed wrecker works perfectly for the move. Widths differ on these roll backs so make sure the company you use has one wide enough. I made prior arrangements for a specific roll back, but when the driver arrived with the smaller truck, he had to return to the yard for the wider deck wrecker.
Click image for larger version
David C.
Howell, MI
RV-10: #41686 Under Construction/Sold 2021
"Donor Exempt" but donated through Dec. 2021
Old 08-19-2022, 09:46 PM
Moresushi Moresushi is offline
Default Call a Moving Company
I called a local moving company. The forward half of my Fuse fit right in the box truck. Plus no wind issues on the freeway.
Bill
Spring, TX
EAA Chapter 302 Member
KCXO Conroe, Texas
RV-10: Under Construction
https://eaabuilderslog.org/?s=wcooper
