VAF on Twitter:
@VansAirForceNet
Old 07-01-2022, 10:10 AM
WingnutWick's Avatar
WingnutWick WingnutWick is offline
Default Fuel qty sender for UBG-16
Anyone know what fuel sender is used on the EI FL-2? I contacted the company and they said it is no longer supported and that I need to send it in to get upgraded to fit with new senders. I am sure spruce still has a sender that'll work.
-Wingnut
F-18E/F, Mk.58, CF-5
Own: RV-8 & RV-10
Old 07-01-2022, 10:54 AM
darata darata is offline
Am I safe to assume you are referring to fuel flow sensor? The UBG-16 cannot monitor fuel level, using the sensors in the tanks. If you are referring to fuel flow, it can be monitored via the FM-FLOW module (necessary to convert a UBG-16 temp channel to monitor flow) and FT-60 flow transducer. Monitoring flow on the UBG-16 is absolutely still supported, however, monitoring fuel level was never an option. I hope this helps.
Dave
Dave Arata
Sales/Support
Electronics International
Old 07-06-2022, 09:52 AM
Mistype there - I meant the EI FL-2. Looks like they only recommend two actually from their old manual though having a hard time finding them on Spruce. Will keep looking. Wasn't sure what was standard in Vans.
-Wingnut
Own: RV-8 & RV-10
