Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
06-24-2022, 02:53 PM
Elastomeric gear
Ok. I switched gears. Waiting on back order parts.
I'm working on the gear and wheel pants and bottom cowl gear slot.
How much does the elastomeric gear move from full weightbto off the ground?
I need a lift capable of raising the fuse high enough to get off the ground.
Planning to buy one of these.
https://www.harborfreight.com/1000-l...art-60438.html
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
06-25-2022, 07:45 AM
when I do wheel maintenance I put a 2x4 under the fuse skin directly under the spar, then one of those long HF jacks under that. Two jacks should lift the whole fuse, but you'll need to support the back as well. I would NOT jack on the fuse at the firewall, though I have lifted the plan via the engine mount, but saw horse at the rear holds some weight.
Larry
06-25-2022, 09:56 AM
Lift
I'm going to work the wheel pants & gear leg fairings. She has no wings. How else can I lift the fuse and make it level long and lat? I plan to make a cradle with a couple 2" boards to fit the center section and use the HF table to lift the fuse. I may use the cherry picker as a safety.
I searched VAF and there are quite a few who lift the entire airplane using a similar set up. Motorcycle jack, Home brew table, HF table.
https://vansairforce.net/community/s...58&postcount=4
https://vansairforce.net/community/s...22&postcount=5
Larry Larson
Estes Park, CO
Disclaimer
06-25-2022, 02:30 PM
Lift
I didn't care for the HF hydraulic table. No lock out to prevent it from leak down. I bought the 1500lb aluminum motorcycle lift. It has a lockout to prevent dropping.
Also went to Home Depot and bought a 4x6x8 treated douglas fir and a 2x6x8. The huge block will be cut into 2 foot lengths. It can be stacked either on the 4" or 6" to build a platform for the lift. The 2x6 will be cut to fit the center section. If not perfectly flat, I will carve it to fit. Should be pretty stable. More to come
Larry Larson
Estes Park, CO
Disclaimer
06-25-2022, 10:39 PM
Got pics of what you did?
06-26-2022, 09:31 AM
Lift
I will post when it's finished. I'm still playing with the blocks to find the most stable combination.
Larry Larson
Estes Park, CO
Disclaimer
06-26-2022, 05:41 PM
Lift
Almost done but first a couple observations.
Turns out, it only takes about 2"-3" of lift to get the tires off the ground. Stability seems to be the biggest problem. Keeping whatever lift mechanism from shifting sideways is the problem. Just like lifting a car. It will want to shift toward gravity. I've learned that lesson with cars. One scissor jack folded right over. Another time two jack stands tilted right over. Gravity is vicious.
1. Lift once or routine use. If you just need to lift the fuse once to fit the pants and fairings, the cherry picker works fine. Build a couple supports and a 2x6 or 4x4 accross the fuse at the center section spar. If no cherry picker, figure out a way to lift then place jack stands at either end of the support. Be careful because there's nothing tieing the two supports to keep the fuse from shifting sideways. Shimming to level is also required so plan accordingly.
2. Multi use lift. The motorcycle lift seems pretty stable considering there's no wings to lift from at the tie downs. I still like lifting at the center section but it would be nice to have a couple supports at the wing tie downs for security.
I will post a photo of the lift tomorrow.
Larry Larson
Estes Park, CO
Disclaimer
06-28-2022, 10:06 AM
Jacks
Originally Posted by Tcheairs
Have you given any thought to the screw style jacks used to support yachts when on the dry dock...should be relatively inexpensive. .very simple process..I use them when my 30,000lb Bluewater Coastal is on the dry dock and trust them completely..Here's a link..Brownell Boat Stands..
<snip>
Yes. I was going that route and I may still. Screw or HF bottle type jacks would work well. The concern is the lateral stability. There isn't any structure locking the two jacks together so the plane can't move laterally. Like I said, I may try them as an alternate method. I can always use them as wing jacks.
It's scarry how something heavy can lean with gravity. I've seen it twice. Once our SUV sissor jack collapsed. I was changing a tire and got up to get something and it came down. Jack looked like a steel pretzel. Another time it was my fault. I had a vehicle on jack stands but the area wasn't level. It slowly went back and landed on the tires. All four jack stands just tilted over. I hadn't removed them yet. I'm a little overly cautious now. Belt and suspenders.
Larry Larson
Estes Park, CO
Disclaimer
06-28-2022, 12:21 PM
For nosewheel maintenance, I just bolted a plate to the hangar floor under the tail and used a block and tackle to pull the tail down. Gets the nose quite high when you can pull the tail down to a few inches from the floor.
In fact, I used an old door hinge so it flops flat when not using it so I don't trip over it. That and a couple Tapcons and you're good to go.
Mike W
Venice, FL
N164WM RV-6A Slider/O-360/FP Sold 4/2022
N184WM (RV-8) Flying. Titan IOX-370/ CS/G3X
N184P reserved (RV-8QB) Empennage kit and QB wings in the shop
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
