Old 01-18-2022, 11:45 AM
CT Brietigam CT Brietigam is offline
Default torque wrenches
I found that buying a new foot-pound Kobalt torque wrench at Lowe's each spring is the cheapest and quickest way to comply with AC43.13-1B. The wrench comes with a certificate of calibration and saves me the time and hassle of shipping it off for re calibration. As a reminder:AC 43.13-1B, 7-40. TORQUES
The importance of correct torque application cannot be overemphasized. Undertorque can result in unnecessary wear of nuts and bolts, as well as the parts they secure. Overtorque can cause failure of a bolt or nut from overstressing the threaded areas. Uneven or additional loads that are applied to the assembly may result in wear or premature failure. The following are a few simple, but important procedures, that should be followed to ensure that correct torque is applied. …
Calibrate the torque wrench at least once a year, or immediately after it has been abused or dropped, to ensure continued accuracy.
Although the regulation only requires “accepted industry practices” be used, the advisory circular explains that the FAA interprets that to mean that all torque wrenches, force gauges, and other tools should be calibrated annually.
Chuck
RV-6XXL
Old 01-21-2022, 09:57 AM
Everwild Everwild is offline
Default CDI 752LDINSS
Let the torqueing begin!
Click image for larger version
David Woodward
Holland, Ohio
RV10
Currently working on the tailcone
Dues Paid Nov 2021
Photos of build progress here.
Old 01-27-2022, 10:10 AM
1001001's Avatar
1001001 1001001 is online now
Default FAT Wrench
For smaller fasteners, I have found my Wheeler Engineering FAT Wrench to be of great use. Alternate source here...
In places where a small screwdriver will fit and a classic torque wrench won't, it's indispensible, and I find myself using it quite a bit all over the airframe. It comes with a certificate of calibration from the factory and can be calibrated as needed.
Old 05-03-2022, 07:40 AM
rongawer rongawer is offline
Default Hey Moderator...
This one should be in Tools.
Done!
Ron Gawer
- RV10, N762G, Build in progress.
- Several others that are now just great memories for me.
