Old 01-16-2022, 07:25 PM
Everwild Everwild is offline
Default Torque wrench recommendations
Any RV-10 builder recommendations on what torque wrench(s) to purchase to get through the build and beyond?
Is there one wrench that will do, or do I need different wrenches for different ranges / jobs?
I like to buy quality tools (buy once) but not necessarily looking for the most expensive option.
What do the A&Ps (professionals) in the crowd use?
Thanks!
David Woodward
Holland, Ohio
RV10
Currently working on the tailcone
2022 Dues Paid
Photos of build progress here.
Old 01-16-2022, 07:44 PM
Default Craftsman at Lowes
I knew almost nothing about torque wrenches. I had never used one until I built my plane. Previously I just tightened nuts on bolts as tight as I could. It never occurred to me a bolt could stretch. I had never built anything out of metal or aluminum and wood is much more forgiving.
I bought 2 of torque wrenches. One for inch pounds and one for foot pounds. I am OK using them and Im sure of my results for direct wrench - socket torque. If you use an extension or other adapters, you could have incorrect results. I have no idea how to figure those. I need a mentor for that.
The other thing to check is accuracy. For that you need someone who knows what they are doing and has a way to verify. There is way more to using them than just pulling until it clicks.
Good luck.
I just noticed you are not that far from me. If you are ever in the Lansing - Mason area, let me know.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 01-16-2022, 07:49 PM
BillL's Avatar
BillL BillL is offline
CDI is a good brand.
I find the wrench part number then google for a price. Like Zoro
Take care and they should last a long time. I have a MAC 250 ft-lb unit purchased in 1974 and it is still in calibration per electronic test. Used on hundreds of engine rebuilds.
Bill
RV-7
Old 01-16-2022, 08:02 PM
wirejock's Avatar
wirejock wirejock is offline
Default CDI
Same here. CDI. Someone mentioned they make torque wrenches for Snap On.
I have a 1/4" in/lb and a 3/8" ft/lb. I also have a 1/4" torque screwdriver. Handy for really low settings down to 5 in/lbs. I wish I had a CDI dial type. It would be nice to read running torque instead of using the screwdriver or multiple tests to figure it out.
My big dog is a Home Depot. Seems fine but hasn't been tested in a long time.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 01-16-2022, 08:22 PM
AV8ER's Avatar
AV8ER AV8ER is offline
Default CDI - Dial type
I have the CDI dial type and love them. Note that a torque wrench has almost no accuracy in the lower scale of its range so lower scale wrenches are necessary. I got a beam type with a ratcheting head for big stuff. Really love that one too.
I wrote up some info on the wrenches I have.
https://n7zk.com/build-log/torque-wrench-solved/
- Tim Jennings
Bought the -10 (Thanks Carl!)
Built the Hangar
Currently building the -8
www.N7ZK.com
"How's it feel to be the fastest plane in the sky? You were spanking two Cirrus planes, a Mooney, and another plane. I took screen shots" - Quote from the best wife in the world.
Old 01-16-2022, 10:05 PM
Thank you for the helpful write up. The VS and HS have #8 and AN3 fasteners, so I'll give the CDI 0-75 in-lb dial type a try to start. The 0-300 in-lb is out of stock everywhere.
David Woodward
Holland, Ohio
RV10
2022 Dues Paid
Old 01-17-2022, 04:42 AM
rgmwa rgmwa is offline
I have 1/4" and 3/8" Norbar torque wrenches. Also very good.
https://www.amazon.com.au/s?k=norbar...l_8pvvra74mr_b
RV-12LR 912ULS 120346
Old 01-17-2022, 05:09 AM
Gusmax Gusmax is offline
This guy does a great job at breaking things down. https://www.youtube.com/watch?v=HP4u...el=ProjectFarm
Phil Kite
F4 Raider project with RV-8 wings and tail
Old 01-17-2022, 06:21 AM
Desert Rat Desert Rat is offline
Snap on. A good torque wrench isn't something to skimp on.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage almost done
Avionics almost done
90% done, 90% to go
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 01-17-2022, 06:50 AM
rocketman1988 rocketman1988 is offline
Default +1 for CDI
+1 for CDI...
...and CDI is the commercial Snap On brand without the name brand cost...
Bob
EAA Tech Counselor
Aerospace Engineer '88
RV-10-ER
N464RL
Going to Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2021,...Thanks DR+
