Old 09-15-2021, 05:36 PM
Lemos Lemos is offline
Default Bad oil analysis results
I received bad news in an email from Blackstone. Looks like my engine is making metal. How bad are these values?
Aluminum 18 ppm. Iron 77 ppm. Copper 30 ppm. Nickel 11 ppm. Everything else is OK.
Blackstone notes: we have found high levels of iron and nickel compared to averages. Check the compressions, and check the oil filter. Resample in ten hours.
What am I looking at here? Engine overhaul? Is there a market for an airplane with an engine with these kind of problems?
Old 09-15-2021, 06:17 PM
00Dan 00Dan is online now
What did you find in the filter pleats? Oil analysis is complementary to actually cutting the filter and shouldn’t be used in isolation.
Old 09-15-2021, 06:34 PM
MacCool's Avatar
MacCool MacCool is offline
I’d check the compressions, check the oil filter, maybe have it borescoped, and re-sample in 10 hours. I think I’d start making plans for an overhaul only based on a demonstrable trend, not a single oil sample.
RV-9A, 2011, bought flying
IO-320D1A
IFR certified
AFS 5400/3500, G5, 430W, some other stuff
Old 09-15-2021, 06:37 PM
sjhurlbut sjhurlbut is offline
Default above
Well oil analysis did its job - I do it every oil change
Do as directed - check the filter and finger screen for any particles. Clean oil and resample as directed.
Have you done several oil analysis or is this the first one?
Its all about trends - chill for a bit but be safe
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
"Stu"
Snowbird #?
Moose Jaw, SK
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - built - sold
4 #2723 - C-GVBX - built - flying!!!!
Old 09-15-2021, 06:42 PM
georgedouglas georgedouglas is offline
Before you go off the deep end, you need to answer some questions like what oil and viscosity are you using, what climate are you mostly operating in, how many hours on the oil, how long has the oil been in the engine, what has been the oil temps generally, How many hours on the engine, was this the first sample, How long do you normally fly each time, what engine maintenance has been done recently. Those PPM numbers are not high enough to condemn this engine or get excited until you find out what you may be doing to push these numbers up. george
RV9A
2TN7 Wolfcreek
President EAA Chapter 17
Knoxville TN
A&P & Private Pilot
USAF 1966-1970
1970-2001 DAL
www.oilhelp.com
Old 09-16-2021, 03:07 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Well, there ain't no in service engine not making metal... the term being normally used when visible metal of kind is found in either the oil itself, or/and the filter(s)
They are high, but I've seen way worse
Blackstone notes: Check the compressions, and check the oil filter. Resample in ten hours.
Have you checked the compressions, have you checked the oil filter, have you resampled after 10 hours, results?
Probably not. Too many unknowns here. The top missing clue is: How many flight hours on that engine prior to the oil analysis, in say the last year, 1/2 year, months? I have seen very hi iron contents, in engines not used for say 3 months, then flown some, and having the analysis done. Most of the time rust scraped off the cylinder walls by the piston rings...
There always is "a market"... just airplane type/state/avionics/engine/time available for sale/etc dependent...
As already stated, oil analysis is one of numerous tools used to assess an engine's health, and certainly not to be used on its own.
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 09-16-2021, 02:55 PM
Scott Hersha Scott Hersha is offline
This is why we do engine oil analysis. You’ve discovered a possible problem, and it may be operator induced, or not. I think you should follow the recommendations given to start to figure it out. The good news is, you can still fly - following the recommendations from professionals, and you are still safe if you follow this advice. SAFE…. That’s why we do it. Good job!
You might want to give Savvy a call. They’ve helped countless aircraft owners with similar problems, and one of their goals is to not do any invasive engine maintenance if not needed. Do your due diligence, give them, or someone else the info, and let them help you.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 09-16-2021, 04:03 PM
Walt's Avatar
Walt Walt is offline
This is why I think oil analysis is pretty much a waste of money, no one has ever torn down an engine based on oil analysis, so all it does is give you something to worry about. Keep flying it and follow Lycoming recommendations checking screens/filters etc., if done routinely you'll end up with the same result.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 09-16-2021, 04:42 PM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Walt makes a good point, additionally it is critical that the sample be taken at the proper time during the drain. We had a mechanic who forgot to take the sample during the drain, realized his mistake and retrieved the sample from the oil filter. Results came back extremely elevated.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Building Javron Super Cub.
2020 dues gladly paid.
Old 09-16-2021, 05:04 PM
RVDan RVDan is offline
Thisis the opposite case, but it is the source of my mistrust of oil analysis, in the short run.
One time, I was starting an annual inspection, took the oil sample, sent it out and proceeded to drain oil through a paint strainer and to cut open the filter. The amount of metal present meant the engine obviously had a problem. Proceeded to engine tear down and found a spun main bearing. The engine was likely only a couple of hours from a stoppage event.
A couple of weeks after the start of the inspection, got the analysis back, slightly elevated levels, recommended checking again at 25 hrs. No sign of the imminent failure.
In essence the analysis by itself was pretty useless.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Retired Aerospace Engineer and A&P/IA
