Old 09-15-2021, 03:28 PM
rileyspoon rileyspoon is offline
Default Bubble, bubble means there is trouble
Did my fuel system pressure test today. Out of what 15 or so connections? I had two that didn't leak. Man I held my breath when cranking on those flare nuts to get them to seal. Followed the instructions but it still took a lot of work getting everything tight enough so that it would hold at 40psi. Took this picture after I started disconnecting the lines so I could tighten the "T" fitting.
Click image for larger version
Riley Spoon
Building RV-12iS
Twin Lakes (8A7) Advance, NC
N488ZC reserved
Old 09-15-2021, 03:49 PM
fr0gpil0t fr0gpil0t is offline
I didn't think you were meant to put sealant on the threads of flare fittings ? But I'm a new builder.
Old 09-15-2021, 05:49 PM
rvbuilder2002's Avatar
Originally Posted by fr0gpil0t View Post
I didn't think you were meant to out sealant on the threads of flare fittings ? But I'm a new builder.
Heís correct. Sealant should only be applied to the NPT portion of fittings and nothing on the side that gets a B nut for aluminum line or hose end.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-15-2021, 06:32 PM
Untainted123 Untainted123 is offline
Default Big No
An RV was lost due to a plug of sealant in the fuel line. Use proper lube on the NPT side and nothing on the flared side of any kind, the flare seating against the flared nipple side is what seals it, and the Al is compressed slightly. If you have used RTV or any kind of sealant that hardens or can come off in a blob, I would audit all connections and clean it all and flush several times before reassembling.
Old 09-15-2021, 06:47 PM
Osprey2gp4 Osprey2gp4 is offline
It appears from your picture that the flare on your tube is way undersize. Maybe Iím wrong, because pictures are sometimes distorted. The flare should be roughly the same size as the flare on the fitting that it mates to. The flare on your tubing looks much smaller than the fitting. Maybe your tubing slipped during the flaring process. Or you didnít have enough tube sticking out past the flaring tool die.
I would take a close look at your flares. As others have said, donít put anything on a flared fitting. The fitting seals by metal to metal contact on the flare surface. A properly made flare will hold in excess of 2000 psi with no sealant on the surfaces.
Best regards,
Bill Wuorinen
RV-7A N237W
Osprey 2 amphibian N137W
A&P I/A
Old 09-15-2021, 08:09 PM
Captain Avgas Captain Avgas is offline
Yep, way undersized...not within spec.
Youíre only as good as your last landing
Bob Barrow
RV7A
Old 09-15-2021, 08:39 PM
6ato14a 6ato14a is offline
Default Flare size
What are you looking at to tell the flare is undersiza?
Old 09-15-2021, 08:42 PM
Good catchÖ. I agree ( I didnít zoom in on the photo when I first looked). It is likely the cause of your numerous leaks
A good guide for a proper flare is that the flare outer diameter should closely match the OD of the sleeve.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 09-15-2021, 08:53 PM
sparkcrafter sparkcrafter is offline
I found this diagram to be helpful in determining the proper flare size. Per the chart, the outside diameter for this flare should measure 0.46Ē-0.49Ē for 3/8Ē tubing.
Old 09-15-2021, 09:46 PM
RFSchaller RFSchaller is offline
Stupid question: are you using an Aviation 37-degree flare? The automotive 45-degree flare will not seal.
