Old 08-27-2021, 03:32 PM
Bungalow Al's Avatar
Bungalow Al Bungalow Al is offline
Default Proud, and Recessed? Canopy Rails
Greetings all,
Currently working on my canopy rails, page 38-12. When I cleco the C-01409, C-01407, and C-01427 all together. The Left side has the C-01407 lower edge recessed below the C-01409. The Right side has the lower edge of the C-01407 sticking beyond the C-01409. See the photos. Both sides are cleco'd in the pre-punched holes on the C-01407. Haven't altered anything. Both C-01409s sit flat on the bench after fluting.
Any thoughts?
Click image for larger version
Name:	Right Rail Marked RZ.jpg
ID:	15116  Click image for larger version
Name:	Left Rail Marked RZ.jpg
Al "Bungalow" Brownlow
RV14 - N714AL Reserved
At the Hideout
"If we're not having fun, we're not doing it right"
Old 08-30-2021, 01:10 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
I had a similar issue and got the C-01409 part replaced by Van's.
It seems to have been a relatively common issue as others that I've spoken to had the same problem. It appears to be a manufacturing issue that the blank can move during the forming process and the bad ones aren't being picked up by QA.
Even my replacement wasn't perfect but close enough.
Send some photos to Van's and ask for a replacement.
