Go Back   VAF Forums > Model Specific > RV-14
Old 08-24-2021, 06:43 PM
SabreFlyr SabreFlyr is offline
Default Straightening curved fresh air vents
After trimming the forward 3/4" of one of my fresh air vents per page 29-21, I still have a substantial curve that takes significant force to flatten. I'm concerned that, even with a good adhesive, it might still pry itself free at the forward end. I'm considering clamping it to the top of my workbench while using a hot air gun (Steinel; capable of somewhere north of 800°F) to soften the plastic. Any reason not to try this? Secondly, how much heat should I consider?
Click image for larger version
ID:	15051  Click image for larger version
Ray Dosh
LJ45 driver
RV-14 #140212
Empennage completed
QB wings 95% done
QB fuse in progress
2021 DUES PAID
Marion, IN MZZ
Old 08-24-2021, 07:41 PM
VA Maule VA Maule is offline
Gently warm it with a heat gun a little at a time until it's plastic (verb) enough to take a new set . Let it cool against flat surface , in a few minutes it aught to be good to go.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 08-24-2021, 08:06 PM
Taltruda Taltruda is offline
800 degrees is too much. Harbor freight sells a cheap heat gun, but you might have luck with a blow drier too
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 08-25-2021, 04:58 AM
I should have added that it is fully adjustable. I'll definitely start on the lower end of its range.
Ray Dosh
LJ45 driver
RV-14 #140212
Empennage completed
QB wings 95% done
QB fuse in progress
2021 DUES PAID
Marion, IN MZZ
Old 08-25-2021, 04:00 PM
abwaldal@gmail.com abwaldal@gmail.com is offline
You have probably seen 2 and 3" conduit used in electrical work. We use a brush burner torch and heat that big thick stuff slowly and when it is in a plastic state just bend it to where we want. 90 degrees, around corners, you name it it goes.
Plastic is very malleable if you take care
Heat away. Art
Old 08-25-2021, 05:24 PM
emsvitil's Avatar
emsvitil emsvitil is offline
Would hot (boiling?) water pot do the trick?
Ed
Old 08-25-2021, 05:43 PM
KeithB's Avatar
KeithB KeithB is offline
Not trusting adhesive, I added several rivets on the perimeter.
Keith Brown
RV-14A Builder - kit #136 (complete) and #770 (in process)
N314KC - First flight Mar 8, 2017, 24th in the air, >750 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2021
Old 08-25-2021, 06:30 PM
Some good thoughts and suggestions! I'll have to mull them over and let you know which way I go and how it works out. Will probably tackle that tomorrow.
P.S.: DR, must have been a slow news day to put this one on the front page!
Ray Dosh
LJ45 driver
RV-14 #140212
Empennage completed
QB wings 95% done
QB fuse in progress
2021 DUES PAID
Marion, IN MZZ
Old 08-26-2021, 01:30 PM
PatMac PatMac is offline
If you have any scrap, test. If not, creep up on it w/ lower heat first. Clamping a conformed piece to it when cooling might help prevent warpage....
Old 08-26-2021, 07:47 PM
FasGlas's Avatar
FasGlas FasGlas is offline
EZ fix.. You can use a cheap HF heat gun. Just wave it back and forth over the area you want to reshape until you feel the glass get pliable, takes only 10 ~ 20 seconds. Lay the piece on a flat surface and use a wet rag to cool it back down. Done.
Beech D17S Staggerwing
Lancair 360
Maule M5-235C
Cessna 120
A&P IA
