Old 08-23-2021, 03:24 PM
Steve Melton's Avatar
Default #3 CHT 15F hotter than normal
After 5 flights with this condition it was enough to make me pull the top cowl to have a look. there it was, bugs, and others wedged in between. a check flight today with 35C OAT. CHTs are normal again, all within 10F. I cannot believe how sensitive the CHT is for airflow around #3 and why bugs only collected at #3.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 08-23-2021, 04:14 PM
wcalvert's Avatar
wcalvert wcalvert is offline
Had a small part of my cowl seal folded back after an oil change. #3 shot up so fast I turned back and landed.
You're right, sensitivity is through the roof ... #3 is my problem child too.
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!!
- Been there, Donated 2021
