Old 08-22-2021, 09:50 PM
PilotjohnS PilotjohnS is offline
Default What did you do with your RV this weekend ( Aug 21,22 2021)
Thanks for asking.
Left side and center stack wiring done.
On right side I realized my GAD29 placemwnt wont let me rivet top skin, gotta move it.
Click image for larger version
ID:	14950  Click image for larger version
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
95% done, 15% left to go
Electrical/Panel 95% done
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 08-22-2021, 11:13 PM
N546RV's Avatar
N546RV N546RV is offline
Finished up all my terminations to the ground block on the firewall:
Decided there wasn't much to do at this point but try firing everything up. After QAing all the connectors and getting everything in place, I...discovered that my bench power supply is apparently a pile of [REDACTED]. Maintains a nice 13.8V with no load, but with a load it's voltage drops galore.
I was at least able to power up the HDX displays individually, but even then the display would flicker sporadically from the voltage drops. Going to try adding a battery in parallel tomorrow, and then go shopping for a better supply. I'm feeling very deprived of a panel full of shiny goodness right now.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 08-22-2021, 11:58 PM
SPX SPX is offline
Not too much
Flew about ten miles down the way to meet up with a friend. Then flew about 25 miles away for lunch, and then did it in reverse.
Had a great time though.
Paid, Jan 2021
Old 08-23-2021, 06:30 AM
cderk's Avatar
cderk cderk is offline
Default Flew to KIAD
Flew into Dulles to volunteer at the Air and Space Museum Innovations in Flight Family Day.
(If anyone knows why images are all upside down, Id love to know how to fix them)
ID:	14973  Click image for larger version
ID:	14974  Click image for larger version
ID:	14975  Click image for larger version
Old 08-23-2021, 09:00 AM
Default My guess
(If anyone knows why images are all upside down, I’d love to know how to fix them)
Just my guess on the images. The iphone has a normal format sideways with the lens up. When the pictures are transferred from the iphone directly to the VAF website, the iphone strips out the megadata (whatever that is) and the orientation is lost, so it defaults to the normal format. When pictures are transferred from a computer to VAF, the mega data is still attached and doesnt get stripped out, so the orientation is correct. The easiest way to fix is to open VAF on your computer, copy the images to the desktop, fix the orientation and then repost from computer to VAF. (I stayed at a Holiday Inn Express last night, so i think this is correct.)
If I want to transfer my pictures directly from Iphone to VAF, i make sure to hold my iphone sideways with lens up; it has worked so far.
John S
RV9A- Status:
Old 08-23-2021, 09:13 AM
jrtens's Avatar
jrtens jrtens is offline
You may also have to crop them a bit to save the new orientation before posting here.
Jon
2019 12iS SLSA
Salt Lake Int'l
Old 08-23-2021, 01:42 PM
wcalvert's Avatar
wcalvert wcalvert is offline
Default Stripping Metadata
Stripping the data also removes all those interesting tid bits like time, date, where the photo was taken, camera used, mother's maiden name, your gender ....
Well, except the last two.
Shooters, be alert!
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!!
- Been there, Donated 2021
Old 08-23-2021, 02:26 PM
jselvatici jselvatici is offline
Talking Long X/C
First time a long run like this, with some flight over the Smoky Mountains and deal with weather next day on the way back.
5 Stars for the controllers. They are a big help. Was on VFR flight following the entire flight and they really look at you to keep you safe.
ID:	15002  Click image for larger version
Juliano
RV-9A / N349RV
1st Flight on 8/14/2020 - Phase 1 done on 11/24/2020
2019/2020 VAF Contribution Sent
Old 08-23-2021, 02:27 PM
unfluencer
A short flight over to Bridgeport for fuel Saturday morning before the heat index climbed to 106. On the way I thought I'd load up the RNAV 18 and let the A/P do some of the work since it was a nice day. Too many sims....I remember when I thought loading an approach was hard. Now *when* do I press the APPR button?!?!
A Stearman from our field was at the pump. Those things sure are neat looking.
v/r,dr
Doug Reeves (your host)
  • Typed in the EMB-505 (Phenom 300). Available for contract work. (flying resume).
  • Part time: Supporting Crew Member CAE EMB-505 Level D Sim @ KDFW.
Old 08-23-2021, 02:54 PM
DanH's Avatar
DanH DanH is offline
Did a bunch of T&G's last night...speed control, spot landing mostly. It was good.
Having flown a lot less in the past year, some of my flying was getting sloppy. Vic and I were talking at the FBO at KPNS a month or two ago. At the time I was really disgusted with my radio performance after an inbound on a busy day with multiple handoffs. Just hadn't been flying much in the stay-at-home year. Use it or lose it. I suspect I'm not alone.
First photo is amazing. I lived in the area back in the 70's, when Dulles was waaaaay out in the sticks, all by itself, and the access highway was the loneliest road in the DC region...
Dan Horton
RV-8 SS
Barrett IO-390
