Old 08-17-2021, 04:33 PM
ryankhallcpa@yahoo.com ryankhallcpa@yahoo.com is offline
Default Re-route the SS Fuel Line to Spider?
See picture. Working on my baffle installations.
You can see that if I install the CB-707D Aft Center Support Bracket that it interferes with the SS fuel line that runs to the spider.
Can I simply flip that Adel clamp 180 degrees and route the fuel line away from the bracket? This may require small bends in the SS line. Is it that easy to bend. What do you recommend?
Thanks!
Ryan
Click image for larger version
Taylor, AZ (KTYL); Builder #74649
RV7 - Emp done; SB Wings done; SB Fuse done; FWF in progress
XIO-360-M1B 9.0:1 pistons; built by JB Aircraft Engines
67 Cherokee 180C - Flying
USAFA - Son (class of 2022)
Donated Q1, 2021
My flight bag is a Dewalt tool bag!
Old 08-17-2021, 04:59 PM
Flyhud's Avatar
Flyhud Flyhud is offline
Flip the clamp and bend the line, it is very easy to bend especially when it’s new.
A&P/IA/ATP
RV-4/160hp/O-320/CS/G3X
Old 08-17-2021, 07:53 PM
Default Easy peezy!
Got it...thanks Tom!
Name:	Easy peezy.jpg
Donated Q1, 2021
Old 08-17-2021, 08:12 PM
Flyhud's Avatar
Looks perfect!
A&P/IA/ATP
Old 08-20-2021, 01:27 PM
rv6ehguy rv6ehguy is offline
Default Another solution
Here’s what I did. Didn’t want to take a chance on kinking the fuel line. Always different solutions to the same problem.
John Van Lieshout
RV6A QB 85%
Aerosport Power IO-375M1S 195hp
Old 08-21-2021, 06:43 AM
riseric's Avatar
riseric riseric is offline
John Van Lieshout
RV6A QB 85%
Just make certain that possible vibration will not have the line touch or rub on the bracket.
Another Adel on the line, attached to the bracket maybe???
Eric,
2021 dues happily donated
RV-8 slow built #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ
Final inspection done!! Waiting for CofA
C-72R Cutlass, flying
Old 08-21-2021, 07:25 AM
Champ's Avatar
Champ Champ is offline
Here’s what I did.
Dennis Enns
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, MTV-9-B/183-50a, PMags, OW Award Oshkosh 2017
2021 Donation In
