Old 08-16-2021, 07:57 PM
N184DA's Avatar
N184DA N184DA is offline
Default Brake Pad Rivets
Anyone s else have this issue:
Changing out my brake pads, like Iíve done countless times before.
Ordered the pads w/rivets through Vans,, again, just like I normally do.
For years Iíve been using the Rapco installation kit. No hammer required, itís a simple twist-squeeze clamp that allows for fairly precise torque.
In all the years I have been installing the rivets, I rarely had seen any cracks,, (in the rivets). Maybe less than a handful over the years and it was probably a result of me just over squeezing.
Fast forward to today:
Every single rivet in the kit that I used cracked. I went through at least 10, before giving up. I experimented with different pressures and when I was successful at not cracking a rivet, it was obviously loose and under squeezed. Re-squeezing = cracking.
I resorted to an old stock of extra Rapco rivets I had ordered a few years ago from AS&S. They went in easily, no cracking.
I have always used the new rivets from the kit, and never had a problem.
Anyone else?
Derrick L. Aubuchon
RV4 (Flying, approx 900hrs)
Tacoma Narrows Airport (TIW), WA
dlaubuchon@gmail.com
(2020/2021 dues paid)
Old 08-16-2021, 08:05 PM
Flyhud's Avatar
Flyhud Flyhud is offline
The shop heads of rivets are allowed up to three small cracks if they do not extend inward beyond the crest of the newly formed head and are at least 90 degrees apart.
Click image for larger version
A&P/IA/ATP
RV-4/160hp/O-320/CS/G3X
Old 08-16-2021, 08:13 PM
N184DA's Avatar
Attachment 14730
Thank you for that.
Within limits or not, seems odd that every one of the new rivets cracked.
P
Derrick L. Aubuchon
Flyhud's Avatar
Also, I use ATS brake pad dies in my hand rivet squeezer to set the brake pad rivets. These are one of the coolest and easiest to use tools in my box!
https://aircraft-tool.com/shop/detai...ookieSupport=1
A&P/IA/ATP
Old 08-17-2021, 05:57 AM
n82rb's Avatar
n82rb n82rb is online now
second on that, I bought a set from bob avery when he first came out with them and have never used my old brake tool again.
bob burns
RV-4 N82RB
Old 08-17-2021, 06:46 AM
lr172 lr172 is offline
I would suspect a manufacturing flaw in the batch of rivets.
Larry
Old 08-17-2021, 06:50 AM
Northernliving Northernliving is offline
I use the Rapco brake rivet tool and get perfect results every time. It's a nice USA-made tool. I've never seen cracks using this tool.
https://www.aircraftspruce.com/catal...RapcoBrake.php
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 08-17-2021, 06:52 AM
N184DA's Avatar
Either have I, until now
Derrick L. Aubuchon
Old 08-17-2021, 05:49 PM
grahambo grahambo is offline
I believe there are two rivet lengths included in the Van's brake pad kits. Would need to be at the hangar to give you the dash numbers, just remember to use the shorter of the two lengths. The pressure to install the longer ones will crack the pads.
Jim Graham
RV-4 Flying
Old 08-17-2021, 05:55 PM
N184DA's Avatar
Good advice but I was definitely using the short rivets.
Derrick L. Aubuchon
