Old 08-13-2021, 05:05 AM
daddyman's Avatar
daddyman daddyman is offline
Default Pneumatic tailwheel
I've wanted to lighten my tailwheel for a the last 4 years.
I finally found one from Matco- P/N WHLTW35 (wheel) TIRT6X2ASY (tire and tube) $ 102 + 24
My issue started because I do not have a standard Van's twin wheel fork with 1/2" bolt, but rather have a single arm- 5/8" locking design.
Once I received the new wheel and tire, I had to sand off .001" from my existing axle. My application also needed 2 spacers.
I ordered them from McMaster-Carr P/N9440T26 and cut them shorted to fit.
Very pleased.
The new assembly is 1.6 pounds lighter.
It is also quieter, taxi and landings are very nice.
Daddyman
Click image for larger version
ID:	14639  Click image for larger version
ID:	14640  Click image for larger version
Happy Donator to Vansairforce.net
700+ hrs in -4
Old 08-13-2021, 09:08 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Thanks for sharing.
Bryan
Houston
Old 08-16-2021, 10:14 AM
Levoe210 Levoe210 is offline
I have the same API single sided tailwheel and have been looking for this solution as well, thank you for sharing
Old 08-16-2021, 10:32 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Towing
Daddyman...
Looks nice.
How do you pull the -4 into the hangar with no nuts for the tow bar to grab on?
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 08-16-2021, 06:00 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Default The 6" is nice, the 7" is better
I used that 6" Matco tailwheel on my -6 for several years, and it is a delight to taxi with. However, it has a tiny air volume which makes it difficult to inflate accurately, which also necessitates adding air almost weekly and the sidewall is so short that a pothole or big expansion joint can easily pinch the tube causing a flat. Had several flats away from home base, so always carried the original tailwheel as a spare.
However, recently Matco came out with a 7" version which still fits the stock Van's fork and has a much greater air volume (relatively speaking; it's still small) and so doesn't have the flat propensity of the older 6" tire. Just remember that to use these pneumatic tailwheels with stock Van's forks you'll need to make a spacer. PM me if you want a CAD model to have one made. Here's a pic of the 7" on my -6:
Old 08-17-2021, 05:38 AM
daddyman's Avatar
Default Mystery towing solved
Originally Posted by Bob Martin View Post
Daddyman...
Looks nice.
Bob,
I went through several towbars before I found one that worked. I think the advertised here on page1 would work, but I'm way too cheap for that.
I simply tuck it in from in front of the tire, then tug. The tailwheel bumps onto dolly-towbar and I can pull it back. Caution: you cannot push it forward, only back.
I'll take a pic or short video and send it to you.
Daddyman
700+ hrs in -4
Old 08-17-2021, 05:39 AM
daddyman's Avatar
Default good to know
Attachment 14726
So far, no flats.
Great to hear the 7" will fit.
Thanks for sharing,
Daddyman
700+ hrs in -4
Old 08-17-2021, 08:31 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Or you might consider a Condor fork and tire from Flyboy.
https://www.flyboyaccessories.com/RV...oducts-s/1.htm
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 08-17-2021, 10:19 AM
Bob Martin's Avatar
Vince,
My hangar mate with a -6 also, just installed one......he loves it and swears his landings are better. He does have to put air in it....and it is not easy being so small a volume....but it looks good and rolls good.
Do you think some slime would help with the air pressure?
We do like the custom axle with the easy to hook on nuts! Smile!
Bob Martin
Old 08-17-2021, 11:12 AM
vfrazier's Avatar
I just "slimed" two lawn mower tires for the same reason. There were no holes in the new tires, they just didn't seal well on the hub.
Actually, it wasn't actually "Slime", I went to the parts store and bought a can of "Fix-a-flat" and simply refilled the empty tires. Working so far.
I can't see why it wouldn't work on a smaller tire also. The volume in the can is probably enough to refill it a several times if needed.
Vince Frazier
www.f1aircraft.com
