Old 08-05-2021, 03:51 PM
PandaCub PandaCub is offline
Default Curious Flat Tire on my RV-14A
Well this a new one (to me, anyway):
After several months with no tire trouble, no hard landings, etc I made an uneventful landing at Bloomington, Indiana. After refueling and taking a 20-minute break at the FBO, I came out to discover my left main was flat.
The folks at KBMG were exemplary and jumped into action to help me solve the problem. We ultimately discovered the flat wasn't from a puncture or leaky valve stem but from a small rupture at the tube's sidewall - in an area roughly same shape as the tire rating stamp that's embossed onto the tire (see photos).
Anyone else ever have this happen? I'm still scratching my head.
Can't see images myself, so here are links:
https://imgur.com/a/tle7rQH
https://ibb.co/Gt9HP1h
John Newkirk
Colorado Front Range/Wyoming Big Horn Basin
RV-14A No. 140308 (N34PB) w/ 330+ Hours
Carbon Cub FX-3 CCX-2000 (N134PB)
Old 08-05-2021, 05:01 PM
Ron B. Ron B. is offline
Do you know if you used talc powder when the tube was installed? We had a similar re-occurring problem on the front tire on our Amph floats. Were trying different tire pressure, different tubes until someone asked if we were using talc. I hadn't heard of it but once we applied the talc on the new tube , never had a flat since. The tube didn't have the shape yours do but it was from the tire rubbings on the tube.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 08-05-2021, 07:39 PM
Christopher Murphy Christopher Murphy is offline
Default Yep..
No or not enough talc or running excessively low pressure.
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
Old 08-05-2021, 07:45 PM
rvbuilder2002's Avatar
Wear spot caused by tube movement against the interior surface of the tire.
As mentioned, caused by too low of air pressure, not enough talc, or a combination of the two.
When I install tires I coat the entire inside of the tire, and I apply a coating to the tube before inserting it in the tire.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 08-05-2021, 08:36 PM
Jake14 Jake14 is offline
Interesting...maybe the effect of stamping the sidewall (making it thinner and less rigid) caused the tire and tube to bulge in that region and present a ridge against which to rub....
maybe the manufacturer should be informed....
RV-14A flying 520 hrs
Old 08-06-2021, 05:29 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Good to know that can happen. What kind of tire and tube? I've been using talc since my motorcycle days in the 70s more out of habit than anything else, and I've never seen a tire rub through a tube. Is there perhaps a manufacturing defect inside the tire?
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 08-06-2021, 09:43 AM
Ralph Inkster Ralph Inkster is offline
Years ago I had a recurring nose tire (Lamb) going flat for no apparent reason. Kept replacing tube and suffering same result. I finally took a close look inside the tire & found a series of barely detectable rubber injection nubs in the sidewall (similar to the ones you find on the treads of some tires). Dremel tool used to smooth them out and never had problem again. & yes, Talc powder is a must.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 08-06-2021, 09:56 AM
wcalvert's Avatar
wcalvert wcalvert is offline
Back in my "road bike" days (bicycle), we would Talc our bottoms to prevent chaffing in the saddle area ...
That same can of talc came out for any tube patching, lots of talc inside the tire and on the tube made everything go together easier and prevented those pesky pinches that would flat a tire in a second.
Old habits die hard (I don't talc my bottom any more) but I sure do talc any tube I install !!!
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!!
- Been there, Donated 2021
Old 08-07-2021, 07:24 AM
Thanks for the insights, gents. I've ordered new Michelin tubes and tires - and a large can of talcum powder!
John Newkirk
Old 08-07-2021, 09:17 AM
plehrke's Avatar
plehrke plehrke is offline
Plus my tires smell baby fresh as I am using up the talc powder my wife no longer is allowed to use.
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
