Old 07-31-2021, 04:12 PM
mfleming's Avatar
mfleming mfleming is offline
Angry Darn - Plate Nuts Misplaced
I'm not sure why this is giving me fits but I can't seem to come up with a simple solution that doesn't butcher the sub panel.
I used a template that was commercially available for my Garmin LRUs. This allowed me to install plate nuts before I received the LRUs...very handy.
They worked perfectly for everything but the GAD-27. The GAD-27 misses the plate nuts and I'm trying to come up with a solution that looks serviceable but doesn't modify the GAD-27 in case it needs to be sent back for warranty work.
Any ideas that don't involve major surgery
Click image for larger version
ID:	14190  Click image for larger version
ID:	14191  Click image for larger version
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Sliding canopy mostly completed 10/2020
Wiring and Avionics harness completed 9/2/2021
FWF Started 9/3/2021
Donated for 2021 and so should you
Old 07-31-2021, 04:18 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Use only two screws to hold it? Build a standoff and mount the GAD-27 to it? Two screws and double-sided tape? Just some ideas, but I'd probably spend 3 days looking at it trying to find a good solution...and come back to the first or second idea. Good luck, I know how frustrating these kinds of issues can be.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 07-31-2021, 04:21 PM
Robin8er Robin8er is offline
My non engineer reviewed opinion is to simply drill another hole in the mounting bracket about an inch to the left of the mis drilled holes and install two more nut plates. Not the most elegant solution, but it prevents replacing parts.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 07-31-2021, 05:03 PM
RV7A Flyer's Avatar
Rotate 90 degrees and make an adapter plate.
2019 Dues paid!
Old 07-31-2021, 05:04 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Drill new hole in the correct location. Install nut plates at a 45 angle to the horizontal. Fill prior nut plate holes with rivets.
Brian Decker
RV-7 (Flying)
Old 07-31-2021, 05:08 PM
bjdecker's Avatar
...and while we're entertaining our OCD -- check the position of the ring terminals, looks like a few of them are installed upside down
Brian Decker
RV-7 (Flying)
Old 07-31-2021, 09:05 PM
PaulvS's Avatar
PaulvS PaulvS is offline
As Mickey said - a clean way is to build a standoff. One way to do this is with a couple of lengths of aluminium 1/2 inch "C" section extrusion.
Or as Brian suggested - just drill some extra holes and rotate the nut plate. Pragmatic and the 6 extra holes in the sub-panel won't do any real harm.
A third way is to rivet the two plate nuts to a loose doubler strip that is the length of the LRU. Blind rivet the doubler strip behind the sub-panel using the 2 right-most holes from the original plate nuts. The only extra holes required will be for the 2 screws to mount the LRU.
I hope you give some feedback to the template supplier to save other future builders from suffering the same fate!
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 07-31-2021, 09:53 PM
mfleming's Avatar
Originally Posted by PaulvS View Post
As Mickey said - a clean way is to build a standoff. ....SNIP....I hope you give some feedback to the template supplier to save other future builders from suffering the same fate!
Yes, I certainly did notify the template supplier...Hope they fixed the problem too.
Thanks for the tips...I'm probably going to make a stand off bracket...I will be able to utilize the already installed plate nuts and won't have a mess of ugly holes looking at me
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 08-01-2021, 07:03 AM
cajunwings cajunwings is offline
Default Templates?
Who sells templates??
Don B
Old 08-01-2021, 09:16 AM
rapid_ascent rapid_ascent is offline
Michael,
This is one of those things that can be seem worse in your mind than it is in actuality. Sometimes we have a plan and when things don't work out the way we planned it is difficult to get past it.
I recently had a problem with my GAD 27 mounting too. I'm mounting mine on the forward ribs. I thought I had it all worked out. I drilled the mounting holes for the GAD 27, GAD 29 and GEA 24 and had the units attached temporarily before I installed the plate nuts. Another VAFer came over (DRAKER) and the first thing he says is that GAD 27 mounting isn't going to work. I had taped over the connectors to prevent them from getting metal shavings in them, but in the process had loss track of one of them. The modules were too close together to plug the connector in. I like you was upset since I had a plan for how all of this was going together in my mind. I walked away from it and when I came back I figured out an easy way to fix it, and yes I have a few "lightening" holes.
So my point is don't make the repair overly complicated. It is a bigger deal in your head than in reality. If you don't want to have to look at your mistake make a doubler, rivet it on and then drill some new holes. Otherwise drill two new holes and install the plate nuts going a different direction.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
