Old 07-29-2021, 08:09 AM
Tankerpilot75's Avatar
Tankerpilot75 Tankerpilot75 is offline
Default Canopy compression struts
I’m sure this has been asked before but what compression psi should the canopy struts have. I know they’re 16” long but when I went to replace them O’Reilly’s air parts had two different strengths 78 and 115 psi. Those seem high but my old ones that have failed and only demonstrate 21.5 lbs compression strength. Canopy will not stay open.
I don’t want too much compression psi in fear of the canopy opening on its own when not secured. In Oklahoma you really need as much air as possible when taxiing on the ground during the summer.
I the second owner.
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Dual GRT Horizon EX with ARINC, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level & auto-trim, Tosten 6 button Military Grips, FlightBox wired to EX, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
Old 07-29-2021, 11:49 AM
azrv6's Avatar
azrv6 azrv6 is offline
I replaced the struts in my RV6 a year ago with these:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Click image for larger version
Name:	Screen Shot 2021-07-29 at 10.48.02 AM.jpg
Other members on this forum had recommended them and they are working very well.
Dave Binkley
RV-6, O-360-A1A, C/S
1932 Monocoupe 110, Warner 145 (http://gobinkley.com)
Sedona, AZ
Old 07-29-2021, 04:32 PM
bjdecker's Avatar
bjdecker bjdecker is offline
I am running with 150N (~34 Ft.Lbs.) on my 7. Canopy stays open when starting/taxiing to beat the Texas heat...
See -- https://vansairforce.net/community/s...t=60434&page=7
and here's the shortcut to what I have now -- http://truck-hardware.orrorr.com/ite...ends/h-9503-35
Brian Decker
RV-7 (Flying)
Old 07-30-2021, 01:45 PM
BruceW BruceW is offline
Ditto on the Suspa C16-08941.
A bit stronger than stock, but not strong enough to twist the canopy around while operating.
Does well when parked on the ramp with winds head on.
Bruce W
RV-7 QB
(500+ hours)
Elk Grove, CA
Old 07-30-2021, 02:39 PM
RicoB's Avatar
RicoB RicoB is offline
Plus one on the Suspa from Amazon. 2 years old and holding strong
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
https://www.imdb.com/name/nm3018529
