Old 07-23-2021, 03:23 PM
TASEsq TASEsq is offline
Default Flap trailing edge riveting?
I canít see any instruction to rivet the flap trailing edge.
I assume it is done between 21-10 step 7 and 8?
(After the adhesive has cured but before bottom skin is pull riveted)
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Old 07-26-2021, 06:28 PM
mc607 mc607 is offline
Yes, any time after step 7. I used a couple pieces of 1ĒX1Ē angle, match drilled to trailing edge to hold in place until proseal sets up. (As per Mitch from Vanís) This works well and can be used again on ailerons. The tape in the picture was abandoned. I rubbed the angles with a light film of Vaseline instead. Didnít want the angles getting prosealed in place. Go easy on the proseal. On my ailerons I went a bit heavy and it resulted in a wavy finish in rivet line.
Click image for larger version
Old 07-26-2021, 08:29 PM
I have used the VHB tape for everything so far but it must be 3 years old now and I’ve heard it has an expiry date - so I might try the Proseal method.
I assume you basically scrape almost all of it off? How do you ensure that it doesn’t build up in the countersinks and hold the skin away from the trailing edge piece? I riveted my tanks wet for this reason - could never believe that a clecod part would be as tight as a riveted one and couldn’t get my head around how the Proseal in the dimples wouldn’t hold the parts away from each other. Or do you clean out the countersinks of proseal somehow? (Difficult since the part is tiny and would have Proseal on both sides.)
Having said all that, apparently the adhesive isn’t structural, so maybe the tape would be fine.
https://vansairforce.net/community/s...22&postcount=7
___________
Trent Stewart
Old 07-26-2021, 10:01 PM
I use bamboo skewers, a scale to measure 10:1 and yogurt lids. I use the blunt end to mix the proseal and then scoop some onto the end of the skewer and roll it onto the trailing edge. Donít let any get in the countersunk holes. If you get some in then soak a qtip in MEK and clean it out. I would recommend making up a small trailing edge from scrap skin and T.E. pieces and give it a try. Go slow and be patient. Donít need much, just enough to ďpaintĒ it dark grey. Itís only as messy as you make it. The skin and T.E. have to be clean first before applying, same as VHB. Need rubber gloves and a shirt you donít like. Usually takes 3-4 days before itís ready to rivet. Keep the leftover proseal sitting in shop near part to check proper setup.
Old 07-27-2021, 09:59 AM
n4322b n4322b is offline
Default VHB Tape
As an ear;ier post suggested It's not structural and so if it has enough holding power to keep the edges together while rivetting (with clecos helping) it will be fine.
The roll I bought for mine is now five years old and functional - the VANS recommended 3M version wasn't cheap in UK.
Far better than pro-seal and quicker
Fuji FA200 / 160 - sold
Sonex - Aerovee - Sold
RV7 in build
RV14 (partly completed by another builder) in the queue
Dues paid 2021 - keep up the good work !
Old 07-27-2021, 02:27 PM
Bavafa Bavafa is offline
Plus one for this method.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 07-28-2021, 08:57 PM
StressedOut StressedOut is offline
Originally Posted by TASEsq View Post
I have used the VHB tape for everything so far but it must be 3 years old now and Iíve heard it has an expiry date - so I might try the Proseal method.
I assume you basically scrape almost all of it off? How do you ensure that it doesnít build up in the countersinks and hold the skin away from the trailing edge piece? I riveted my tanks wet for this reason - could never believe that a clecod part would be as tight as a riveted one and couldnít get my head around how the Proseal in the dimples wouldnít hold the parts away from each other. Or do you clean out the countersinks of proseal somehow? (Difficult since the part is tiny and would have Proseal on both sides.)
Having said all that, apparently the adhesive isnít structural, so maybe the tape would be fine.
If you apply sealant with a foam roller you will not deposit any of it in the countersinks. It only puts it on the surfaces it touches. You can get the rollers in the aviation department at Home Depot.
Art Jackson
RV-14A Kit#140433
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator, Rudder #2, Aft Fuselage)
Ordered: Wing Kit (Arrives March 2021)
Construction log - mykitlog.com/ajackson
Dues paid on March 2021
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
