Old 07-22-2021, 09:32 AM
Jeffcc17 Jeffcc17 is offline
Default A question about torque seal
Hello,
I am currently working on the fus of a 10. I have put torque seal on the tails of the bolt and nut but recently I have seen pictures from kit planes and Vic S where the torque seal is on the head of the bolt. Am I putting it on the wrong side? Thanks in advance.
Jeff
Ps I was going to put a picture in here, but need the tutorial on that too.
Old 07-22-2021, 09:46 AM
jrtens's Avatar
jrtens jrtens is offline
Attach your photo by using the paperclip icon.
Click image for larger version
Name:	attach a photo.jpg
Jon
2019 12iS SLSA
Salt Lake Int'l
Old 07-22-2021, 09:51 AM
pa38112 pa38112 is offline
Wherever you can see if there has been rotation. I have seen examples of the torque seal breaking off of the threads without breaking the torque seal. This allows the clump of torque seal to spin with the nut, and it looks intact. For that reason I usually run a bead of it from the part to the nut to the threads.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 07-22-2021, 09:57 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Torque seal is cheap.
Do both if you think it will help.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-22-2021, 11:08 AM
Here you go.
Old 07-22-2021, 12:18 PM
Brian Perry Brian Perry is offline
I usually put the Torque Seal on the nut side, but in areas where the nut side is difficult or impossible to see for inspection I will put it on the bolt head side as well.
Brian Perry
RV 14A Kit #140588
Airworthiness Certificate Issued 1/9/2021
First Flight 1/23/2021
Old 07-22-2021, 01:16 PM
Thanks for your posts.
Old 07-22-2021, 03:14 PM
TASEsq TASEsq is offline
Someone told me you should not put it on the threads - can cause galling if the nut ever has to be removed - to put it from the nut down to the structure. This is what I’ve been doing. In some places where a bolt goes into a nutplate - like the bolts that hold the fuel tank on then it has to be on the head of the bolt.
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Old 07-22-2021, 04:39 PM
DanH's Avatar
DanH DanH is offline
Torque seal is useless. Spend the time re-checking the torque with a wrench.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-22-2021, 04:55 PM
MGR1977 MGR1977 is offline
Default nail polish
So I've been using lacquer nail polish. All you need is to mark the nut relative to the part so that you can see if any rotation happened. Diving for cover!!
