Old 07-21-2021, 07:19 PM
jrock836's Avatar
jrock836 jrock836 is offline
Default Heading back to hangar for Round #2
I'm trying to put my RV12 back together after much disassembly to install my ADSB-IN... I had to unbolt the Flaperon Mixer Bellcranks in order to run the coax under all the pushrods and bellcranks and drill some holes. I spent almost 4 hours earlier trying to line up everything including that dang washer on the bottom in order to slide the bolt in through 6 different holes... No joy... As anyone who has done this before knows, there are lots of restrictions that make working in that area VERY difficult. I finally decided I needed to just walk away from it for awhile before tools started flying..
I'm about to head back for round #2 right now. I just thought I would see how other people managed to get it done. I'm planning to use a very small spot of super glue to hold the washer in place and see if that will work. Anyone else have any other brilliant solutions? I will check for any posts once I get to the hangar. Hopefully someone has a better way. I already tried to stick the washer in place with Easy Turn, but that didn't work. Washer kept moving around as I lined up everything else... UGGG...
Click image for larger version
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
DONATED
Old 07-21-2021, 08:17 PM
Mich48041 Mich48041 is offline
Try putting a very strong rare earth magnet on the bolt head.
Joe Gores
RV-12 Flying
Old 07-21-2021, 08:50 PM
Bob Y Bob Y is offline
You might try using a punch, awl or pick through the parts to get things aligned before inserting the bolt.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
Old 07-21-2021, 09:16 PM
seagull seagull is offline
I had a similar situation when I was reinstalling my control sticks after changing grips. There are small spacers on each side of the heim rod end that have to be in place before the bolt goes through, similar to your situation. There is only enough room for one hand. I spent / wasted several hours and increased my vocabulary with a few new swear words when I "almost" had it together several times.
In the end the super glue putting the spacer on the heim rod end worked first time. The second stick went together in 5 minutes. Good luck.
Live as if you were to die tomorrow. Learn as if you were to live forever.
-- Walt --
Old 07-21-2021, 09:54 PM
jrock836's Avatar
Thanks, I probably didn't explain it well enough. Getting the washer in place is the biggest challenge. I dropped the washer countless times while trying to blindly slide it into position under the complete assembly with one finger. If I ever got the washer close I would have tried your idea.
Thanks.. The super glue is setting up as I type and admiring the new antenna.
Joe
DONATED
Old 07-22-2021, 12:37 AM
I probably should have said I ran the bolt through with nothing else to act as a guide for the spacer. Then a dab of super glue on the spacer and dropped it on the bolt letting it fall in place. After it dried I removed the bolt and assembled like you only a couple of fingers doing all the work.
-- Walt --
Old 07-22-2021, 06:53 AM
jrock836's Avatar
Thanks Walt.. I got that assembly back together late last night! I hope to never take that part of the airplane apart again.
Joe
DONATED
Old 07-23-2021, 12:37 AM
Janekom's Avatar
Janekom Janekom is offline
I have a set of washer spanners that I use all the time. Available from Cleaveland Tool
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 07-23-2021, 09:52 AM
OK, I'll bite, whats a washer spanner?
-- Walt --
Old 07-23-2021, 07:38 PM
dsm8 dsm8 is offline
Default Round 2
I feel your pain. A spanner is a thin peice of metal taht is machined to hold a washer in place and you slide it with close tolerance. Best Money I every spent
Name:	washer wrench.png
Don "Donnie Mac" MacMillan
RV-12 12808
Finish kit 80% done 80% to go
donald.macmillan@ynhh.org
