Old 07-17-2021, 04:56 PM
PhatRV PhatRV is offline
Default How To Make Baffle Tension Rod
I am at the stage to make the baffle tension rods. I am having trouble threading the ends with the threading dies. Is there a technique to get the dies started?
Better yet, is there seller for these ready made tension rods?
Thanks.
The tension rods are described in the picture below.
Click image for larger version
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Done. Fiberglass 80%
Avionics Installation -- 90%
Firewall Forward -- Cowl completed. Baffle 90%
Electrical -- 90%
Donation paid through 2021
Old 07-17-2021, 05:10 PM
RV10Pilot RV10Pilot is offline
I started with a harbor freight die. No joy. Bought a high quality die and it
T was a piece of cake. Some have used threaded rod in lieu of having to thread the ends. Others have used safety wire inside plastic tuning in lieu of the rod.
Old 07-17-2021, 06:33 PM
DanH's Avatar
DanH DanH is offline
Give them a floatation test.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-17-2021, 06:35 PM
lr172 lr172 is offline
I struggled on the first set, as i only had a bench vice and couldn’t keep the rod from slipping. Second set done on a lathe and very easy. Find a holding apparatus designed for round items. Chuck the rod in your drill and clamp the drill chuck in your vice.
Or pre cut them and mail to me with a bottle of wine and will thread them for you.
Larry
Old 07-17-2021, 06:48 PM
fl-mike's Avatar
fl-mike fl-mike is online now
Safety wire, as Dan shows.
Mike W
Venice, FL
N164WM
Old 07-17-2021, 06:56 PM
scard's Avatar
scard scard is offline
safety wire. 2300+ hrs.
Scott Card
CMW E-Lift
VAF Advertiser
Old 07-17-2021, 07:02 PM
PilotjohnS PilotjohnS is offline
Default black goop
I see the washers the wire goes around to keep the stainless wire from digging into the aluminum baffle, but what is that black goop for?
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
95% done, 15% left to go
Electrical/Panel 95% done
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 07-17-2021, 08:15 PM
larrynew's Avatar
larrynew larrynew is offline
I’m using DMC Safe-T-Cable instead of safety wire but everything else the same as Dan. Only 200 hours but everything is still well secured.
Larry New
RV-7A - Built, flew 950+ hrs, sold
RV-10 - Built, flying 250+ hrs
RV-12iS - All kits ordered!
VAF on Annual Autopay
Old 07-17-2021, 08:32 PM
DanH's Avatar
Permatex Ultra Black, aka Loctite 598. In this case a dab kills any relative motion due to vibration.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-17-2021, 08:52 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Originally Posted by PhatRV View Post
Better yet, is there seller for these ready made tension rods. . .
The safety wire does work. However, your local aviation department at Lowe’s or Home Depot will have threaded rod that will work also.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
