Old 07-07-2021, 03:44 PM
Flyer2017 Flyer2017 is offline
Default How to place remote boxes on subpanel
I'm changing my panel from round gauges to two AFS EFIS with an Avidyne 540 and remote com panel. Trying to figure out how to arrange all the boxes on the subpanel and ribs. Looking for pictures of how others have done it. The 540 projects thru the subpanel which takes up a lot of available space for other boxes. Any pictures or referrals to builders logs would be helpful. thanks
RV-9A, 0-320, FP Prop, paid 2021
Cessna 140A 0-200
Old 07-08-2021, 08:40 AM
RV7 Heaven RV7 Heaven is offline
I installed an AFS panel in my RV-7. Here are some pictures of the panel and how I did the sub panel. Let me know if you have any questions about what I did.
Click image for larger version
Name:	Powered Panel.jpg
ID:	13406  Click image for larger version
Name:	IFD 540 Cutout.jpg
ID:	13407  Click image for larger version
Name:	IFD 540 Mount Installation.jpg
ID:	13408  Click image for larger version
Name:	ACM Install.jpg
ID:	13409  Click image for larger version
Name:	Backup Battery Install.jpg
Name:	COM Radio Install.jpg
ID:	13411  Click image for larger version
Name:	PDA360EX and EMS Installation.jpg
ID:	13413  Click image for larger version
Name:	Sub Panel ELT Installation.jpg
Greg B
Palm City, FL
Building RV-7 / #73557 / N558GB (Reserved)
2021 Dues Paid
Disclaimer: The information presented in this post is my opinion. Anybody using this information has the responsibility for determining the accuracy and suitability for its use.
Old 07-08-2021, 09:22 AM
rapid_ascent rapid_ascent is online now
I'm just getting to this point on my build. I'm using a Garmin G3x system so its different than your install, but similar problem. The G3x has lots of little boxes that need to be mounted somewhere. I'm still trying to figure out where for most of them.
You can use the sides of the forward ribs as well as the sub-panel. My sub-panel like yours has a big hole in it to all for my GNS-430 so the center isn't available. Right now I have a fuse block mounted on one of the available sides. The forward section of the ribs are fairly wide so they worked for mounting 2 of my boxes. These will be difficult to get to once the forward skin is installed so I plan to use hex head screws and nut plates to make it a little easier to remove install. I allowed some room at the forward end so that I could get a tool and my hand in there for install/removal. The pic shown is just a test fit.
I'll probably need to make one or more shelves of some sort under the sub-panel area. The bottom of the ribs in the center, forward of my sub-panel cutout look to be a good option. I'm trying to make sure that I have enough access though. I may need to test fit my radio stack before I can figure that out.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 07-08-2021, 11:49 AM
wcalvert's Avatar
wcalvert wcalvert is offline
Default Shelves
I build a row of shelves across the aft side of the panel forward of the instrument panel. Held all the Dynon boxes and then some. Decent access behind the panel.
ID:	13427  Click image for larger version
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!!
- Been there, Donated 2021
Old 07-08-2021, 12:16 PM
Bill,
That looks like a pretty nice solution.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
Old 07-09-2021, 07:44 AM
dougweil's Avatar
dougweil dougweil is offline
Someday….. somehow…. You will have to remove these items for repair. Use nut plates and caps crews or you will be faced with a nearly impossible task of trying to remove and replace them!!
Doug Weiler
Hudson, WI
president, Twin Cities RV Builders Group
RV-4, sold
RV-7 completed and flying N722DW, 930 hours
Based Lake Elmo, MN (21D)
Old 07-09-2021, 12:00 PM
Draker's Avatar
Draker Draker is offline
I "borrowed" an idea from another builder and made a flat, removable shelf between the subpanel and firewall:
It held most of the "goodies" that don't need to stick out of the panel:
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/31/2020
RV-7A (N12VD): Everything done that can be done at home. Waiting for hangar to finish up.
Old 07-09-2021, 02:08 PM
sf3543 sf3543 is offline
I have worked on lots of planes where the builder installed remote boxes behind the panel that were almost impossible to access because they didn't consider the skin that was going to be installed over them.
When installing stuff behind the panel, make sure you allow for future maintenance. This would include being able to remove the boxes as well as access the wiring. If you don't, you may regret it sooner than you think.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
Legend Cub
Old 07-09-2021, 05:15 PM
sahrens's Avatar
sahrens sahrens is offline
Default Shelf
Like Ryan I built a shelf behind my sub-panel. It is hinged so I can lower it to get to the avionics installed on it. Vans sells an access panel kit to give access from above.
https://shop.vansaircraft.com/cgi-bi...ccessPanelsKit
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
Old 07-09-2021, 07:16 PM
wirejock's Avatar
wirejock wirejock is offline
Default Hinged panels
My boxes are not installed but I fabricated mock ups of everything. After seeing how much real estate was used, I fabricated two panels from the instrument panel to the sub panel. They are hinged fore and aft so they can swing either way or be removed simply by pulling hinge pins. Really makes the instrument panel solid too.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
