Old 07-07-2021, 07:49 AM
KLax18 KLax18 is offline
Default Help- landing light conversion to LED RV-8
What is a good conversion landing light from my current wing tip landing lights? One current bulb burnt out so I want to go to LED. Thanks
Click image for larger version
Old 07-07-2021, 08:44 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
For the complete conversion there is "The Works" from Flyleds.com https://flyleds.com/products/#!/The-...651/category=0
For the landing light by itself there is this option of a drop-in replacement for the MR-16 halogen: https://flyleds.com/products/#!/Sing...015/category=0
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 07-07-2021, 12:15 PM
azrv6's Avatar
azrv6 azrv6 is offline
First thing to do is verify what bulb you have in your wingtip. Can't tell for certain from the picture, but it looks to me like it might be a PAR 36 bulb. Commonly used and easily replaced with units from a variety of sources, aviation and non-aviation. If it is a PAR 36 bulb the replacement is a simple task. Search with google: "PAR 36 replacement site:vansairforce.net" and you will find all kinds of suggestions.
Dave Binkley
RV-6, O-360-A1A, C/S
1932 Monocoupe 110, Warner 145 (http://gobinkley.com)
Sedona, AZ
Old 07-07-2021, 12:19 PM
Nate Calvin Nate Calvin is offline
AeroLEDs Pulsar NS (NAV/ACS), SunTail (POS/ACS) and AeroSun Vx (landing/taxi/wig/wag)---GREAT Seat up
Old 07-07-2021, 05:19 PM
Carlos151's Avatar
Carlos151 Carlos151 is online now
+1 for FlyLEDs. At least four times as bright with a quarter of the amperage draw from the Vans light kit. Straight drop in replacement for the wingtip lights.
Karl Richcreek
RV-8
N151TK "La Otra Chica"
Flying as of August 14, 2015
TN26
Old 07-07-2021, 09:11 PM
Default Thank you
Ordered the fly-ledís.
Old 08-03-2021, 06:11 PM
vomatic vomatic is offline
Default Paint on FLYLED's
Those are awesome. How did you paint the circuit boards on your FLYLED's?
David
RV-8 QB
Tail - Done
Fuselage - In Process
Old 08-04-2021, 05:57 PM
Paul from Flyleds's Avatar
Paul from Flyleds Paul from Flyleds is offline
We encourage you to build the kit first, then mask the LEDs and paint the boards to suit your paint scheme. That way you can cover up the solder joints on the board as well.
Use low tack painting tape to avoid damaging the LEDs. A couple of customers have also used Liquid Latex to mask the LEDs, which brushes on and peels off afterwards. Use the rest of the bottle for Halloween makeup later on!
Thanks to Carlos for answering the OP!
Paul McVitty
Flyleds.com
VAF advertiser
