Go Back   VAF Forums > Model Specific > RV-14
Old 07-06-2021, 03:56 PM
NordicDave NordicDave is offline
Default Engine Control Placement
I'm looking hard at an RV-14A. I'm wondering why we don't see many if hardly any RV-14A's with the engine controls placed in a more ergonomic position like the center console as seen in the Socata TB-10 or TB-20?
It would be nice to drop the right hand down and have a hand on these controls with out reaching.
Socata's are are very comfortable as they were designed in an era when pilot ergonomics were a design consideration.
Click image for larger version
Name:	Socata interior.PNG
Old 07-06-2021, 04:02 PM
Mel's Avatar
Mel Mel is offline
One of the reasons you don't often see this is that it takes up valuable space in a tight cockpit. When the time comes that you need to crawl under the panel, you'll see what I mean.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 07-06-2021, 04:23 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
In addition to taking up unnecessary space, push/pull controls (with vernier mixture and prop) for me at least are more practical.
Iíll leave the quadrant in the RV-8 however.
Carl
Old 07-06-2021, 04:47 PM
Mongoose Mongoose is offline
Cleaning/changing the fuel filter would also be even more difficult.
__________________________
Phil LaMar
Los Gatos, CA
RV-14A N1414A
First flight Jan 23, 2020
Dues paid 4/2020
Old 07-06-2021, 07:58 PM
czechsix's Avatar
czechsix czechsix is offline
It certainly could be done in a -14 (some RV-10s have a center console with quadrant), but it adds cost, weight, complexity, and as others have noted makes maintenance more difficult.
Mark Navratil
Spring Hill, KS
RV-8A N2D #80583 - built/flew/sold
RV-14A #140017 - wings complete, empacone in progress...
Old 07-07-2021, 10:33 AM
Thanks for the guidance, the replies make sense. Perhaps the quadrant engine control module only between the seats. Should be easy to unscrew and lift up for accessing fuel filter?
Old 07-07-2021, 10:58 AM
lr172 lr172 is offline
That is not your main issue. Suggest you find a buddy with a 7 and try to access behind the panel on your back. Pretend you are soldering or crimping wires and installing tie wraps with one hand. Now imagine the incremental difficulty if there was a console in the way.
Larry
Old 07-07-2021, 12:32 PM
RhinoDrvr RhinoDrvr is offline
Isnít the canopy on the -14 easily removable? Seems the main benefit of the tip up canopy has been touted as better avionics access behind the panel?
Evan Levesque
RV-8 N88MJ (Built by Michael Robbins)
Lemoore, CA
Old 07-07-2021, 12:37 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
But not underneath. There's a lot down there you still can't get to from the top.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Donated August 2021
Old 07-07-2021, 12:41 PM
MED MED is offline
Isn’t the canopy on the -14 easily removable? Seems the main benefit of the tip up canopy has been touted as better avionics access behind the panel?
It is “removable”, but that would involve disconnecting wiring, too, which would not necessarily make it easy. Most of the avionics on and behind the main panel can be accessed from the seats or standing on the ground next to the airplane. In my case, there are additional things located behind the sub-panel, but aft of the firewall, which require some headstands/contortions.
MED
140236
N435MD
Miss March 2020
