Old 07-06-2021, 03:16 PM
Roberson35 Roberson35 is offline
Default Identify Recognition/Landing Lights
Gents:
Can anyone help me identify these Lights? Iím hoping to find a replacement bulb for one which has gone out. They are installed in the leading edges of both wings.
Click image for larger version
ID:	13355  Click image for larger version
ID:	13356  Click image for larger version
ID:	13357  Click image for larger version
Old 07-06-2021, 05:05 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Originally Posted by Roberson35 View Post
Gents:
Can anyone help me identify these Lights? I’m hoping to find a replacement bulb for one which has gone out. They are installed in the leading edges of both wings.
55watt GE H3 halogen bulb
http://duckworksav.com/LELightKits.html
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 07-06-2021, 05:15 PM
bruceh's Avatar
bruceh bruceh is offline
Any autoparts store or Wal-Mart will have that H3 bulb. My Mazda uses that same bulb. Do not touch it with your bare fingers when installing it. Any oils from your fingerprints will create a hot spot on the glass and the light will burn out quickly. Clean it with alcohol if you touch the bulb.
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2021 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 07-06-2021, 07:28 PM
papamike's Avatar
papamike papamike is offline
I replaced mine with LED bulbs even before first flight. H3 bulbs. I had trouble finding the LEDs in stores; got them on Amazon.
Pete Miller
RV-7 Phase 1 !!!
N174PM
McKinney, TX (T31)
http://smilinpete.com
Old 07-06-2021, 08:05 PM
moosepileit moosepileit is offline
If you stick with the H3-sized LEDs, the ones with enough lumens make significant RFI and need toroid magnet choke clamps on the positive leads. 55W H3 halogens are poor lumens per amp and 100w are too much draw overall for some.
Small LED H3s have only a few 100 lumen throw.
You'll want enough length to loop through the chokes 3 times.
Edit to add, I would replace the beam holder with a plate and mount 2 spots and a taxi in each, depending on if tail or nosewheel and amount of lumens vs amps desired. No noise, easy kits. Paul's FlyLEDs
https://vansairforce.net/community/s...27&postcount=2
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Old 07-07-2021, 07:19 PM
Many Thanks, Friends!!!!
