Old 07-04-2021, 05:13 AM
dmaib's Avatar
dmaib dmaib is offline
Default Many will identify with this
Just finished my Condition Inspection last week and it had a couple of frustrating moments. I came across this and thought it was perfect!
Click image for larger version
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2021
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 07-04-2021, 06:34 AM
Sam Staton Sam Staton is offline
Default Yup
So painfully true.
RV6 N585SS - building on!
O-360-A1G6D converted to A1A
Dual Powertek EFII
VPX-Pro
Astronics PPS
Hartzell C/S
Dynon SV1000 & SV700
Old 07-04-2021, 07:24 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Yep
Just started my Condition inspection. Planned to quickly get the compression test out of the way - except #1 tested out at 60 psi with loud hissing through the exhaust pipe . The "inspection" period just got longer . . . . .
Dan Langhout
2021 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
818 hours and counting . . . .
26 Pilots N Paws Flights
Now based at Moontown (3M5)
Old 07-04-2021, 11:13 AM
mbauer mbauer is offline
Default Experienced More Than Once
More than once! Every project I try!
Here is something that made some sense of how I felt after a grueling 1558 mile flight one fuel stop/lunch break for fuel, day ended with 9.9 hours of flying. Some of it unplanned due to a weather reroute.
Slept 11-hours, woke up and drove to breakfast at a favorite location: Was craving a Garbage Can Breakfast Burrito from a local restaurant.
Carla had a new sign up. It explained exactly how I felt at the moment:
Best regards,
Mike Bauer
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 07-04-2021, 03:52 PM
merlin3 merlin3 is offline
My annual started with two cylinders that were a little low. Borescope revealed cylinder walls that I didnt like. So 4 cykinders later and its fixed.
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 07-04-2021, 04:34 PM
Plummit's Avatar
Plummit Plummit is offline
Default Here ya go.
-Marc
RV-10
N814RV
2021 Donation Made
Old 07-04-2021, 04:41 PM
DRMA DRMA is offline
No broken bolts on my first condition inspection, but several stripped screw heads that required drilling out and in a couple of cases replacing the plate nuts. I hate phillips head screws!
Dave Macdonald
RV-10 First Flight April 1, 2020. Phase 1 Complete
2021 VAF Dues Paid (plus a little more)
Old 07-04-2021, 05:08 PM
F1 Rocket F1 Rocket is offline
So true. When I installed the dual electronic ignition in my airplane last year I had to remove the bearings in the accessory case that supported the original magnetos. What was supposed to be an easy task of removing them turned out to be two weeks worth of effort involving the purchase of several different types of tools that didn’t work. Of course once I found the right tool… It was a 20 minute job :-)
Danny
F1 Rocket #25
N14ZM "Dreamer"
Melboring, FL
Old 07-04-2021, 08:54 PM
rv6n6r's Avatar
rv6n6r rv6n6r is offline
Haha my version: Every two day condition inspection is one engine mount crack away from becoming a two month ordeal.
Randall Henderson
RV-6 / O-360 / CS, 1600+ hrs, 1st flight Sept. 1999
Outstanding Workmanship OSH 2000
Airport committee chair & AOPA ASNV for Seaside, OR Municipal (56S), www.seasideairport.org
Donated August 2021
Old 07-05-2021, 06:11 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Attachment 13311
I would SO buy one of those plaques...no, I'd buy 3 of them (1 for me, and two for close friends who know all about this)
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
