Old 06-29-2021, 05:20 PM
JeremyL JeremyL is offline
Default Rudder horn/reinforce plate extra hole
Before I hit up vans tech support, does anyone know what these extra holes are for. They are not drilled through the spar yet. I donít see them listed on the plans anywhere. My assumption is for something later but I donít know. This is for an RV 7, feel free to move this to the 7 room, but I wasnít sure if it was an across the board thing to be drilled later. Thank you!
Click image for larger version
ID:	13225  Click image for larger version
ID:	13226  Click image for larger version
_____________________________________________
RV7A(in construction)
https://eaabuilderslog.org/?s=N524JL
Old 06-30-2021, 05:34 AM
Desert Rat Desert Rat is online now
I believe those parts are common to the RV14 and thats where those holes are used. I asked Vans about this back in the day and was told that I could either ignore them or match drill them to the spar.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 06-30-2021, 07:02 AM
Karetaker's Avatar
Karetaker Karetaker is offline
Howdy Jeremy. I drilled/riveted those holes in my-7 when building the rudder.
Mike
Vans RV and Pietenpol Channel
https://www.youtube.com/channel/UCna...sOaZYjSWIGeXlQ
Old 06-30-2021, 07:23 AM
Excellent! Thank you, Iíll drill and rivet them as well. Extra rivets canít hurt.
Old 07-01-2021, 06:22 AM
bob865 bob865 is offline
I'm building an RV-8 and it has the same phantom holes. I reached out to Vans support and got the following answer:
There are some parts commonality between aircraft models.
You can leave those holes un-riveted and unused
-or-
Fabricated a new larger shim of about the size and include those holes.
The choice is yours.
Rivets would be the same: AN470AD4-X (x=appropriate lenght)
--Adam
First Time Builder
RV8A- Status:
Empennage Kit: In work (85%-ish)
Wings Kit: Ordered (Standard Build)
https://eaabuilderslog.org/?s=Adam_RV-8
