Old 06-27-2021, 08:57 AM
JoopSJ's Avatar
JoopSJ JoopSJ is offline
Default Identify this bolt size Sup cold air sump
I have a Superior cold air sump. Underneat thera are two locations where you can bolt a bracket or so.
Anyone could tell me which size bolt go in here?
I tried AN3 but I don't go past the first thread and don't want to force it.
Click image for larger version
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017. . . 2020
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
Old 06-27-2021, 09:21 AM
Norman CYYJ Norman CYYJ is offline
Try a 1/4 20.
Old 06-27-2021, 09:49 AM
JoopSJ's Avatar
Originally Posted by Norman CYYJ View Post
Try a 1/4 20.
Is that the same as AN4?
Do you have the part number?
Sorry, I live in metric world.
Member EAA
Member AOPA
Old 06-27-2021, 10:28 AM
Bcone1381 Bcone1381 is offline
I would not expect an AN bolt to fit into a threaded casting of a Lycoming Case.
All AN bolts have fine threads. The O-360 Parts Manual show typically (may be exclusively) that Lycomoing used coarse threads.
Old 06-27-2021, 10:45 AM
No it a course thread and very common
Old 06-27-2021, 10:50 AM
agent4573 agent4573 is online now
Try MS35206-281 or AN515-416R12 or R16.
I'll be replacing mine with McMaster part
https://www.mcmaster.com/90124A542 since they're prefilled for safety wire.
www.rv7build.com
N69ER - reserved
Old 06-27-2021, 11:28 AM
Mel's Avatar
Mel Mel is offline
As said before, AN bolts are fine threads. Fine threads are seldom used in castings. If it is 3/16" it would probably be a 10-24. If it is 1/4" (most likely) it will probably be a 1/4-20. If it's 5/16", probably 5/16-18.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-27-2021, 11:40 AM
wcalvert's Avatar
wcalvert wcalvert is offline
Joop
For an easy example, this is the same thread as the Hex head bolts holding your valve covers on.
Cheers
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
First Flight 7/17/2021!!
- Been there, Donated 2021
wcalvert's Avatar
Should have said "Philips" style heads. Pan head philips
RV-7 Tipper
Anacortes, Wa
Old 06-27-2021, 12:55 PM
deek deek is offline
OP is in Europe; my experience in finding UNC fasteners in UK and Germany was frustrating.
'83 LongEZ - N888EZ 3,371 hours (sold)
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: RV14 or Rans S-21 ; need something to build
