Old 06-22-2021, 01:15 AM
MalteJ MalteJ is offline
Default Thunderbolt vs. Standard IO-390
Hey guys,
I am looking for some detail pictures that show the differences between the Thunderbolt IO-390-EXP119 and the standard Lycoming YIO-390-A3B6.
The different air intake, fuel system etc.
Also I would like to know how does the RV-14's lower cowling differ between both versions?
Do you have some pictures?
Thanks a lot!
Malte
Old 06-22-2021, 06:15 AM
DanH's Avatar
DanH DanH is online now
The new cowl's air exits are the two fairings around the tailpipes, and a variable area door in a cover over what was formerly an open tunnel.
The intake changes are a revised fiberglass snorkel, an AFP FM200 injection, and the 390 C/D model's intake manifold, which has a larger inlet bore compared to the traditional integral plenum sump.
Click image for larger version
Name:	Cowl Off with Variable Exit.jpg
ID:	12907  Click image for larger version
Name:	New Lower Cowl and Tunnel Cover.jpg
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-22-2021, 04:50 PM
RV7ForMe RV7ForMe is offline
Originally Posted by MalteJ View Post
Hey guys,
Malte
Not sure it matters, but you can also get the new EXP119 in the NON Thunderbolt version (standard Lycoming). My buddy has it in the 14a.
There are quite a few changes. The Oil cooler is a bit changed. The Air intake is redesigned and also the the throttle body is now from Air Flow Performance. It's the gold looking thing on Dans picture.
The exhaust is different, hence the bottom cowl must be because of the new exhaust pipes.
The RV14a now has a cowl flap in the tunnel where the original exhaust was...
Based on the performance numbers. The difference is Huge!
VAF dues paid for 2021
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
