Old 06-19-2021, 07:55 AM
HFS HFS is offline
Default DIY Compound Taper Shim - Turning Fixture
Here is a pic of a fixture I made, for making compound taper shims to accommodate camber & toe in/out conditions at the same time.
Four set screws, at the corners, can be adjusted in two planes to resolve camber and "toe" issues at the same time.
There is a small "lug" left at the center after turning, but is easily removed - either by sawing off, then polishing flat; or, use a precision hole saw (Rotabroach) to remove the offending material.
YMMY - And probably will.
HFS
Not shown - axle mounting holes: Need to be oriented properly to yield correct "adjustment" prior to beginning turning on a lathe.
Click image for larger version
Name:	Cmpd Taper Shim Turning Fixture .jpg
Old 06-19-2021, 12:38 PM
Smary setup. Wish I could add a shim to my -6A gear. The bend in the gear is off from left to right, so one tire wears more on the outside.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 06-19-2021, 12:48 PM
Kyle Boatright Kyle Boatright is online now
If your left tire is wearing more, the issue is probably torque on takeoff.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
