Old 06-17-2021, 06:35 AM
MDeCraene13 MDeCraene13 is offline
Default Micro-Stop Cage Rebuild
My micro-stop cage was behaving erratically, so I took it apart and found a bearing that looked like the attached image.
I decided to attempt to rebuild it and posted the details on my build log here:
Build Log Post Link
The bearing I used was McMaster P/N 7806K64.
I have not used my rebuilt cage extensively, so time will tell how it holds up.
Click image for larger version
RV-8
Empennage complete except tips.
Wing complete except bottom skins and tips.
Fuselage started
Build Log
Old 06-17-2021, 08:52 AM
John Tierney John Tierney is offline
I'm guessing somebody used that in a drill press and pressed way too hard.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 06-17-2021, 08:59 AM
Dan 57's Avatar
Dan 57 Dan 57 is online now
well, shouldn’t happen on good quality tooling... had one those ATS cheapies bought in 1986 (...), and the Chinese balls were kinda soft (...), the resulting oblong countersinks leading to VS #3 whilst building the -4
And that was the day I decided to buy top quality tooling only
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 06-17-2021, 09:23 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Couple of those look more like cubes than balls
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-17-2021, 09:29 AM
Taltruda Taltruda is offline
I bought some used ones from fleabay, and they were all gritty and unusable. Less that 10 minutes each and I had them like new again! The bearings didn’t seem damaged, but they were dried up and crusty. I thought they were needle bearings in mine, but they might have been balls. Whatever they were, they weren’t captured, and I had to make sure I got all of them back in there with a drop of oil!
Tom
Las Vegas
RV-4 flying…
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 06-17-2021, 09:52 AM
Very nice write-up in your log, thanks!
Dave
Old 06-18-2021, 06:32 AM
pdecraene7a pdecraene7a is offline
Thumbs up micro stop
Nice airplane drawing on the work bench
Pete DeCraene
Joliet, IL
RV-7A CONVERTED TO RV-7 526PD
