Go Back   VAF Forums > Model Specific > RV-9/9A
Old 06-14-2021, 07:24 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default Why do the plans call for this bolt to be upside down?
This is the bolt that holds the Exit Air Attach Contraption, er Brackets to the firewall. It is supposed to be installed head down.
That seems odd to me, so I have mine with the head up.
Does anyone know why the plans show it upside down? All I can think is that it keep the AN365 nyloc nut out of the hot air flow, but I can't believe that would matter.
Click image for larger version
Name:	Screenshot 2021-06-14 081752.png
ID:	12616  Click image for larger version
Name:	Screenshot 2021-06-14 081901.png
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
Old 06-14-2021, 08:15 AM
Greg Arehart's Avatar
I would have thought because it is difficult or impossible to insert the bolt from the top if the engine mount is in place, but obviously you have done that so must be some other reason.
Greg Arehart
N 7965A
Old 06-14-2021, 08:22 AM
Yeah its super easy to install the aft bolt from the top... unlike the forward bolts which are darn near impossible to get the nuts on!
Marion IA
Old 06-15-2021, 07:38 AM
lr172 lr172 is offline
The head creates less drag than the nut plus threaded portion. Not a flight safety issue, so no need to account for failure modes.
Old 06-15-2021, 07:41 AM
Thanks! I actually wondered about that, but didn't think it would be significant.. I'll flip it around and get another 0.0000001 knot haha!
Marion IA
Old 06-15-2021, 07:45 AM
Mel's Avatar
Mel Mel is offline
I doubt you will see that much improvement.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-15-2021, 09:14 AM
Snowflake's Avatar
Not without a 3D printed fairing for it, at least. Where's Steve?
Rob Prior
Old 06-15-2021, 09:18 AM
PilotjohnS PilotjohnS is offline
Default Every time
I think every time someone crawls under there to wipe it down or do work, they are going to be thankful that bolt is upside down. If it is put it in with the head on the top side, one might consider putting a cap on the threads that are sticking down. JMHO
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
95% done, 15% left to go
Electrical/Panel 95% done
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 06-15-2021, 02:08 PM
plehrke's Avatar
plehrke plehrke is offline
Designer’s Discretion.
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 06-16-2021, 04:56 PM
agent4573 agent4573 is offline
Best practice is to install bolt heads forward, up, or out. If you deviate from best practice there should be a reason for it.
www.rv7build.com
N69ER - reserved
