Go Back   VAF Forums > Model Specific > RV-14
Old 06-13-2021, 08:34 PM
WayneJ WayneJ is offline
Default My nuts are galled, 25-05 step 8
I installed the AN3-13A bolts then realized I chose the wrong Cover Rib so removed the bolts and found badly galled threads. We all know these all metal locknuts work like platenuts (nutplates?) and are deformed to apply an interference fit as the locking mechanism. But is it normal to get this kind of galling? The photos show the relative location of the nut when installed. The bottom of the nut is not deformed and does not cause galling. Nylock nuts are re-usable but I have not read that all metal locknuts and the bolts they are installed on are one time use only. I will not reuse these. I this normal?
Click image for larger version
ID:	12601  Click image for larger version
Wayne
S50, Auburn, WA
120642
140736
Old 06-14-2021, 05:32 AM
RV6_flyer's Avatar
That is NOT normal.
Not sure where your info comes about metal locknuts not being reusable but it is false. Metal locknuts, just like nylocks, are reusable if they still provide resistance.
Been using metal locknuts like in your photo for over 20-years and have never seen one like that. Looks over torqued or maybe I should say it looks like an over tighten fastener.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 06-14-2021, 05:45 AM
terrykohler terrykohler is offline
Default Hard to tell by looking at the Pictures
Best if you look at these using a magnifying glass. It's not unusual for all-metal lock nuts to strip a little plating. You'll be able to tell pretty easily if it's just a little plating or it's really galling with some magnification. Look at the thread form.
Terry, CFI
RV9A N323TP
Old 06-14-2021, 09:22 AM
Norman CYYJ Norman CYYJ is offline
Looks like the wrong thread on the nuts.
Old 06-14-2021, 09:29 AM
PhatRV PhatRV is offline
I had to throw out a couple of metal nutplates that had damaged the bolt threads like in your picture. Most of the AN parts have tight tolerances but they aren't perfect. Find and new metal nut and test it with another new bolt. You should be able to screw on / off a few times before the threads give out.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Done. Fiberglass 80%
Avionics Installation -- 90%
Firewall Forward -- Cowl completed. Baffle 90%
Electrical -- 90%
Donation paid through 2021
Old 06-14-2021, 12:47 PM
Instead of using a new bolt use the old bolt and thread the nut on further. If it is still a problem you haven't wasted another bolt.
Old 06-14-2021, 02:28 PM
Scott Hersha Scott Hersha is offline
I agree with Terry. I think you are seeing CAD plating removal because of the tight fit of the lock nut. The nut is CAD plated too, so the initial fit gets very tight, loosens up a bit when the plating is scraped off, but still performs as a lock nut.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 06-14-2021, 03:16 PM
HAL Pilot's Avatar
HAL Pilot HAL Pilot is offline
If you can turn the nut by hand it's time to replace it.
Pete
RV14A Tail kit 95%
Wing kit 95%
Fuselage QB stuck in China virus corrosion purgatory
RV 14 WIKI in Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
please purchase the thumb drive Vans offers. I DO NOT want to take away from sales flow or get the WIKI Killed.
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 18,19,20,21 Military exempt
Old 06-14-2021, 05:24 PM
Walt's Avatar
Walt Walt is offline
Agree, looks like coarse thread bolt with MS fine thread nut, stripped.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 06-14-2021, 07:32 PM
Default I could be overthinking this.
The thread size is verified 10-32 on both parts. Not the wrong size or pitch.
Looked at the threads under magnification and can see what looks like galling. Blobs of metal in the threads. It doesn't show up well in the photos.
Ran the nut on and off both bolts about 6 times each. They went on and off just fine, got looser though. The prevailing torque started at about 8-10 in lb and is now about 5 in lb.
I used a scribe and a brush to clean out the threads. Lots of fine particles. This could be plating particles but the color looks like steel. Maybe both.
Bottom line, after playing with this today I think it's a non issue. The assembly seems to be sound in spite of the way it looks.
Just for fun I put one of the (2) bolts that I've been playing with into the assembly and over-torqued it. Went up 10 in lb at a time and it held to 100 in lb. At 110 in lb the threads started to strip and the wrench would not click.
My final torque calculation is 28 + 8 = 36 in lb. Per the chart on KAI page 05-20 and measured prevailing torque of 8 in lb.
Maybe someone out there could try this to see if you get the same result. AN3 bolt and MS21042-3 nut.
Wayne
S50, Auburn, WA
120642
140736
