Old 06-13-2021, 11:51 AM
unfluencer
Default What did you do with your RV this weekend? (6/12/21 - 6/13/21)
...getting it started.
v/r,dr
Doug Reeves (your host)
  • Typed in the EMB-505 (Phenom 300). Available for contract work. (flying resume).
  • Part time: Supporting Crew Member CAE EMB-505 Level D Sim @ KDFW.
Old 06-13-2021, 12:52 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Breakfast in Birmingham
Flew from Huntsville to Birmingham to have breakfast with my son. Flight included an approach to minimums at KBHM.
Dan Langhout
2021 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
818 hours and counting . . . .
26 Pilots N Paws Flights
Now based at Moontown (3M5)
Old 06-13-2021, 01:01 PM
RWoodard's Avatar
RWoodard RWoodard is offline
I tried to make my standard breakfast run to KGXY (27nm), but it was socked in with low clouds, so I ended up going to Granby (KGNB-56nm) to look at a potential vacation condo.
The look-see didnt take long and the clouds burned off so I ended up back in GXY after all for a brunch-ish breakfast. Low clouds on days when its going to be 95 degrees are somewhat unusual around here.
I went up to 13,500 feet for a few minutes and there was almost no wind and zero bumps. Pretty incredible machines we have!
As an aside, Ive put out a few feelers, but if anyone knows of someone with hangar space for an RV3 in Granby, Id be interested in talking.
Rod Woodard
Brighton, Colorado (CO12)
RV-3 IO-320
Old 06-13-2021, 01:54 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Skies clear, perfect morning for some pattern work. Driving out to the airport, uh on, thin wisps of clouds coming in from the west, quickly. By the time we were ready to take off, it was few at 700 and more coming in. What to do? A pair of LPV approaches to different runways, just for practice. 0.8 hour flight, 0.1 hours actual. The most interesting part was that the wind just above the clouds was 35 knots from the west, but only 8 on the surface. Forecast winds at 3,000 were about 20 knots. That was worth calling Flight Service with a Pirep once we got back down. Leaving the airport, the clouds were a broken layer.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
Vaccines kept me out of the hospital but COVID still cost me a month of living, all told...
Old 06-13-2021, 10:34 PM
goatflieg's Avatar
goatflieg goatflieg is offline
One photo is worth a thousand words (many of them curse words) but I'll use three:
Basecoat is ON!
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - registered; final assembly continues; still putting out my own brush fires.
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2021... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 06-14-2021, 12:25 AM
Major-Tom's Avatar
Major-Tom Major-Tom is offline
Default I met a twin, I didn't know I had
This weekend I met a serial Vans builder at Mueritz Airpark in Germany. We did a lot of chatting, had diner and enjoyed the company having a beer late at the runway. I felt almost like meeting your twin. And look at the photo, we almost look alike... ;-) I would have loved to get a ride in his RV-14, but there was no opportunity this time.
Click image for larger version
D-MDYZ ICP Savannah-S built, flying, sold www.savannah-blog.de
D-ERVM RV-12iS #121128 99% done, waiting for first flight admission www.tomsworld.de
Old 06-14-2021, 12:28 AM
SPX SPX is offline
Great shirts!
Paid, Jan 2021
Old 06-14-2021, 05:14 AM
newt's Avatar
newt newt is offline
Default VH-SOL refurb "second first flight"
VH-SOL, RV-6 s/n 21068, has been down for refurbishment since mid February.
Engine overhaul. Rewiring. Instrumentation refit. Gazillions of little fixes and improvements.
We returned to the skies with my O-320-D2A rebuilt as an IO-320 by Andrew Jolly at Riverina Airmotive in Parafield, with a Precision Airmotive Silverhawk EX fuel injection system and a P-Mag electronic ignition replacing the impulse magneto (I'll do the other one in a few months, all the wiring is ready and waiting for it). Inside the fuselage I now have a dual-screen Garmin G3X panel with engine monitoring, GNS430W, Garmin autopilot, remote mount GTR20 COM.
The EIS, PFD and primary ADHARS are dual-powered from the main bus and an essential bus with its own battery. G5 backup flight instrument is on an avionics bus with its own backup battery. Lots of redundancy, designed for reliability and IFR.
The refit has also dismantled and rebuilt 25 years worth of modifications by two previous owners. Grounding has been rebuilt, circuit protection has been applied correctly to everything.
And the sub-panel was hacked to pieces over many years of changes. That's been filled-in, reinforced and stiffened.
The rewire extended to the engine bay. All the wiring runs are properly supported with p-clamps, with slack loops in appropriate places. Massive tidy-up and improvement.
The result is a return-to-service of a 25 year old RV-6 that's been updated to 2021 standards. The same airplane, but where everything we touched has been made better.
I put the first 30 minutes on the new engine by flying circles above Goolwa Airport (YGWA) in South Australia at the end of Friday, just in time for the weekend.
https://youtu.be/EBRQhg9LDDA
I put another 1.3 on it this afternoon, doing system tests between YGWA, YMBD and YSFG. I still have some calibrations to do (the G5 ADHARS hasn't been reset since I turned it from standalone into G3X Backup, so they don't quite agree), but they're minor tasks, and it's essentially finished.
CHTs on initial climbout are about 390F, at 2400 RPM 150 knots IAS leaned to 28 litres per hour they settle down to about 360F, or 345F at full rich.
Very happy with how it turned out. I've been carrying a mental picture of this project around in my head for a year now, and it's immensely satisfying to see it rendered into physical form. And, even better, almost all of it worked first time.
Great thanks to Lyndon Tretheway, my LAME (Australian A&P equivalent) who has done most of the work while I've been learning skills, holding wrenches and gophering. I've been incredibly impressed with the way that he's improved on my design ideas. We've spent two and a half weeks of collaboration with pretty long days to get it to this point, and none of it would have been possible without him. I can't recommend his RV expertise highly enough.
Aside from the second P-Mag, the final piece of the project is the interior refit. There's a set of seats, side panels and tonneau covers waiting for me at home in Sydney, delivered while I was 1400km away doing this work. My plan is to get back home next weekend, and I'm really looking forward to seeing how it looks when the finishing touches are applied.
- mark
ID:	12609  Click image for larger version
ID:	12610  Click image for larger version
ID:	12611  Click image for larger version
[ Paid up on 16 Jul 2021 ]
RV-6 VH-SOL
Old 06-14-2021, 06:07 AM
rvanstory's Avatar
rvanstory rvanstory is offline
Default Cornhole boards
First flew north for about an hour just to exercise the plane. Then came home and finish my cornhole board project. Fun game to play when hanging out. Was pretty happy with how they turned out.
ID:	12613  Click image for larger version
Randy Vanstory
Flying RV10 - N783V
2021 Sun N Fun Reserve Grand Champion
2021 Oshkosh Bronze Lindy
1st Flight 08/20/2020
Donation Happily Made 2021
Old 06-14-2021, 07:31 AM
Plummit's Avatar
Plummit Plummit is offline
Twin? Not even close! One guy is very handsome and the other has hair...
-Marc
RV-10
N814RV
2021 Donation Made
