Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
06-06-2021, 04:17 PM
Prop Balance - How Much Weight to Add?
We are balancing a RV-12 prop with DynaVibe. It's our first experience doing this. The unit is telling us 0.4IPS x 50 grams starting point = 20 grams weight.
Does that sound reasonable?
How much weight have folks added for balancing?
Thanks in advance...
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
06-06-2021, 04:28 PM
See page 32 of the attached I received from the manufacturer. Mine was pretty close to this guide.
https://www.dropbox.com/s/8vhcmufjxc...eller.pdf?dl=0
Remember you’ll be increasing the weight when you move it to the spinner backplate. Since the spinner is ~10” diameter, mounting at 8” gives a nice round increase of 25%.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
06-06-2021, 04:50 PM
Right... what I'm wondering is how much weight folks have used to balance the Sensenich ground adjustable prop on RV-12. I'd like to see if we are in ballpark...
06-06-2021, 05:23 PM
As a reference, I used 36.8 g on the spinner perimeter - 46 g on the 8” diameter.
#121047
06-06-2021, 05:35 PM
Jim,
I ended up with about 19g on the back plate of my -12, drilled at a 9" diameter to get .03ips
Friday I did a Lycoming 320 with a Hartzell 2 blade. With no weight is was .43ips. The finished solution was 17.8g on a 10" diameter to get .04ips.
Live as if you were to die tomorrow. Learn as if you were to live forever.
visit my blog - http://waltsrv12.com
-- Walt --
06-06-2021, 06:19 PM
RV-12 Sensenich - DynaVibe
Mine was 19.4 grams at the 9" diameter, for 0.08 ips final.
Tony
E-LSA RV-12 ULS
06-06-2021, 11:59 PM
The guy who did mine added one #6 machine screw to the spinner bulkhead. Hardly seemed worth the effort.
06-07-2021, 12:02 PM
my buddy ended up adding just 1 washer under an existing spinner #8 screw. His readings were fairly good to begin with.
On mine, I started with 0.30-0.34 IPS and ended up adding 13g at a hole that was appox 3/4" from the spinner backplate edge. End result was about 0.04 IPS
Incidentally, I rent out my DynaVibe for $100 to any builder that needs it (up to a maximum of $1400.. as I'm looking only to recoup costs and not make money off it)
Rob Carsey, Winfield Park, NJ
RV-12iS (N713) / Completed 12/2020 / 350hrs and counting
ASEL, Glider, AGI/IGI, LSRM-I, FCC GROL
APRS Track or ADSBExchange Track
06-07-2021, 01:33 PM
Mine was .50 after adding 27 grams it came down to .05 I used a 1/4" NAS bolt and 2 OD washers and lock nut to mid span of spinner bulkhead 180 degrees opposite of heavy spot...piece of cake.
06-16-2021, 04:19 PM
gram scale
I just finished balancing the Sensenich prop on my RV12. before the balance it registered .17 in/sec after balance we got it down to .05 in/sec.
Now the rub! I added one #8 x 1/2" screw with a nylon lock nut at 4.5" from the center of the shaft. My gram scale said that the screw and nut only weighed 3.8 grams. Everyone else seems to be coming up with much higher weights to do the balance.
I hope the scale is not wrong because it is the same one I use to weigh the carburetor floats and they came in at 6.7 grams for each pair.
Any thoughts?
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
