Old 06-03-2021, 08:03 AM
CessnaTPA CessnaTPA is offline
Default Trim Pushrod Issue
I have a question that I'm pretty sure I know the answer to.
When I match drilled the trim pushrod I was off a little which caused the rivet not to sit perfectly square. As you can see in the pic it caused the rivet to fold. When I went to set the 2nd rivet it started to do the same so I stopped. What would you recommend?
Click image for larger version
ID:	12174  Click image for larger version
ID:	12175  Click image for larger version
Old 06-03-2021, 08:10 AM
Bob Y Bob Y is online now
For the function they serve they’re probably ok, but I wouldn’t compromise build quality on something like this. I’d carefully drill them out. But from the photos, they appear to be too long. Double check the size before reinstalling.
Bob Y - builder 12iS E-LSA
N569TT first flight 2/9/2020
#121047
Old 06-03-2021, 09:15 PM
RFSchaller RFSchaller is offline
The rivet is in shear. The shop head is basically a retaining device to keep the rivet in the hole. I wouldn’t worry about it. But yon can never go wrong replacing it unless you screw up drilling it out.
Old 06-04-2021, 04:17 AM
Not the prettiest rivets but feel it's acceptable.
ID:	12237  Click image for larger version
Old 06-04-2021, 02:02 PM
Janekom's Avatar
Janekom Janekom is offline
I think they are really good
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 06-04-2021, 08:26 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default How are you riveting them?
I found if I wasn’t VERY stable with those, folding was a problem. My final technique was well jigged pushrod in my c-frame and my 3x gun with the pressure up 10-20 psi from normal. That first hit or three really made the difference. I had more problems with the aileron pushrods. I made a few extra before I found my setup.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2021 VAF contributor
Old 06-04-2021, 08:30 PM
I used a hand squeezer.
Old 06-04-2021, 11:24 PM
jrock836's Avatar
jrock836 jrock836 is offline
Smile
I know the feeling.. I didn’t build my plane, but have been doing upgrades. At one point I was stressing about how some of my rivets were looking, but finally realized that I wasn’t going to crash since I was only installing brackets to hold my ADSB-IN box behind the panel.
Joe
Van's RV-12 #120566 - ELSA - N49DD
Spinks Airport, KFWS, Fort Worth, TEXAS!
DONATED
