Old 06-02-2021, 07:48 AM
catmandu's Avatar
catmandu catmandu is offline
Default Spinner wear only at hub?
A nice crack popped up on my spinner, so I planned my standard fix of backing the area with some carbon fiber thread to strengthen it and fill on the top. Upon removal of the spinner, I found that the area right next to the leading edge of both FP prop hubs have an approximately two inch wear strip from the front bulkhead, as if the bulkhead is slightly oval in shape, with no wear anywhere else around the circle of the spinner. Seems kind of coincidental to have it on both sides, any particular reason for this?
Mike C.
Sierra Nevada
RV-6A bought flying
Old 06-02-2021, 08:25 AM
rvbuilder2002's Avatar
I have seen this when no screws were installed in the fwd. bulkhead.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 06-02-2021, 02:37 PM
catmandu's Avatar
Six screws for the forward bulkhead. Maybe those 25 year old plate nuts need replacing to tighten things up.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 06-03-2021, 02:33 PM
SPB W10 SPB W10 is offline
Check the "legs" of the nut plates for cracks. We found all of them broken on the long leg fixed nutplates. This was an aluminum spinner composite bulkhead combination on 180 hp Lycoming.
Steven B.
A&P
1980's RV-3 & RV-4 Build Support
Lincoln, NE
2021 DUES PAID THOUGH EXEMPT
