Go Back   VAF Forums > Model Specific > RV-4
Old 05-26-2021, 07:16 AM
propflipper propflipper is offline
Default Rv-4 Firewall component installation
Hello everyone. I am ready to begin installing all of the accessories attached to the RV-4 firewall. Brake reservoir, solenoids, battery (maybe), etc. I will have horizontal fuel injection and a constant speed prop. A photo of a layout would be very helpful. Thank you in advance for permitting me to benefit from your labors.
Tom
Rv-4 wings, emp, fuse done
Old 05-26-2021, 07:56 AM
fixnflyguy fixnflyguy is offline
Default A couple things
The -4 is a bit of a challenge due to size and various configurations. Certain things must be in proper orientation. First concern is engine control cable routing and pass throughs. For my carbureted O-320, they come out through the tunnel low and near centerline. Cabin heat, depending on your plan for that has to be routed with ducting from the heat muff. Your oil cooler location can also impact what can be behind it. Here are a couple pics of mine, though not prefect, have worked well so far. My battery is in the tunnel, but I have room to go on right side of firewall if I want. My heat box is on L/H side, but muff is on R/H pipes, so SCAT tube runs around back. My pressure sender manifold is on L/H upper side. The brake reservoir needs to stay centerline and high. Fuel line and smoke system lines are in tunnel down low. Both solenoids are in tunnel on cabin side and out of the way. Really need engine hung to know some things or face relocating them later. Plan carefully, cut/drill once!
Click image for larger version
Name:	O320 right side.jpg
ID:	11956  Click image for larger version
Name:	O320 left side.jpg
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 05-26-2021, 08:09 AM
Default More pics of my -4
Here are a couple more pics I have on file.
ID:	11958  Click image for larger version
Name:	Tunnel routing.jpg
ID:	11959  Click image for larger version
Name:	Engine controls.jpg
ID:	11960  Click image for larger version
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 05-26-2021, 08:28 AM
Default Firewall
Great stuff Bill. Thanks a bunch .
Tom
Old 05-27-2021, 11:09 AM
n82rb's Avatar
n82rb n82rb is offline
i would seriously consider NOT putting the battery FWF. even a light weight battery. with a constant speed prop on a 4 you will be very forward with the empty cg. I have a 360, metal hartzell cs, light weight starter and alternator.i am forward of the cg limit empty with the battery in the stock location.
bob burns
RV-4 n82rb
Old 05-27-2021, 03:36 PM
Thanks Bob
