Old 05-21-2021, 10:18 PM
crabandy crabandy is online now
Default What did you do with your RV this weekend? (5/21-5/23)
I suppose I’ll get it started and attempt the new and better pic hosting!
Finished the oil change and under cowling lube and look-see just in time to pick up my lil’ dude after school. Back to the airport to toss our bags in the RV and pop some clouds for an hour on the way to the lake. I hope he never loses his enthusiasm for flying with dad.
Lots of varying layers made for a scenic and interesting flight!
Click image for larger version
ID:	11837  Click image for larger version
ID:	11838  Click image for larger version
ID:	11839  Click image for larger version
ID:	11840  Click image for larger version
RV 7 500 hours and counting
20 donation done
Old 05-22-2021, 10:10 AM
dbaflyer dbaflyer is offline
Default A few touch n gos at KCID
Got a bit of pattern work in before the drizzle started.
Denis Sailer - Eastern Iowa
RV9A - N649DS - 132 hours
RV-9
Old 05-22-2021, 05:58 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default Baird to Terre Haute
Baird the German Short Haired Pointer needed to get to Chicago. I took him from Muscle Shoals, AL (KMSL) to Terre Haute, IN (3I3).
As you can see from the photo, I carefully briefed Baird before the flight.
Dan Langhout
2021 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
818 hours and counting . . . .
26 Pilots N Paws Flights
Now based at Moontown (3M5)
Old 05-22-2021, 06:20 PM
koupster's Avatar
koupster koupster is offline
Andy,
Looks like you passed the pic hosting challenge.
Nice performance! 160 KTAS at 7.2 GPH = 25.55 statute mpg at 184 mph.
Cheers, David
RV-6A - KBTF
Old 05-22-2021, 07:15 PM
mchargmg's Avatar
mchargmg mchargmg is offline
Default Changed the oil and took a short flight
One of the cadets and I were testing the range of a low power transmitter by driving around town, and we wound up close to the airport. I asked if he likes to fly, and of course, he said yes. So he helped me change the oil (who knew that was fun), and after we took a short flight before the weather rolled in. Click image for larger version
Blues skies
Geoff
Geoff McHarg
2021 dues gladly sent
Old 05-23-2021, 04:23 AM
Saville's Avatar
Saville Saville is offline
Practiced landings.
Lately they haven't been the greasers that I like. I wasn't managing that last foot very well.
When this happens I know that some bad habit has crept in. So I stayed in the pattern yesterday and shot 6 landings. Last 3 were greasers.
Also the wind shifted and the pattern was busy so I got to change runways mid-pattern and ATC kept calling for long downwinds and changing left traffic to right and back to left, searching for numbers 1,2 and sometimes 3 who are landing first. This was actually very good because most of my approaches are straight-in approaches.
I also chose to go around once as I was doing a touch and go, and the plane ahead of me was coming to a full stop. I judged that ATC placed us a little too closely together so that was good practice too.
Flying RV-8 N880BC
2021 Dues - happily paid.
Old 05-23-2021, 08:56 AM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Default Went out with a photographer
Friday afternoon we went out with a photographer for a quick shoot out of Heritage Field. Ken was the photographer and he just sent this to me. Had a great day flying with Mike for this photo op.
David
EAA 1250 KPTW
Royersford, PA
david@rv12pilot.com
2021 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 05-23-2021, 11:22 AM
Tom023 Tom023 is offline
Default Repairs weekend
Weather kept me on the ground this week so completed Saturday the following:
- replaced faulty EGTprobe
- replaced Sky Tec starter under warranty
- installed Aircraft Specialty twin wing root fuel filters replacing the single Andair filter
- installed AFP auxiliary fuel pump replacing the Andair pump
- installed ASA oil separator
RV14A #140083
Flying! 8/12/19
2020 Donation
Old 05-23-2021, 01:10 PM
Joe Joe is offline
Default Rudder Trim
I bench-tested the components for electric trim on my RV-8A's rudder. The two aluminum parts on the right form a bridle (I think that's what it's called) that captures the right rudder cable just forward of the spar. The red/black wires are connected to a DPDT center-off polarity reversing switch.
Still to do: mount actuator's clevis to the forward baggage compartment wall (near the right rudder pedal) and find a console location to mount the switch. And remove my fixed rudder trim tab.
Name:	Rudder Trim Components.jpg
Joe Dubner
RV-8A
Independence, OR
Old 05-23-2021, 02:08 PM
N546RV's Avatar
N546RV N546RV is offline
I've been making things pretty in and around my aft avionics shelf.
All bundles finalized, adel clamps temporarily attached:
Harness branches going forward (under the right armrest) and aft (for the ADAHRS and tail stuff):
Testing final fit with the adels screwed in and the baggage well in place:
Making nice tidy wire bundles sure is satisfying.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
