Old 05-15-2021, 07:38 AM
Daida's Avatar
Daida Daida is offline
Default What would you do....?
Okay, an engine found its way into my hangar (all legal!)
What i know:
-O-470 with all accessories
-not run in 15 years
-not pickeled for long time storage
-lay in the corner of the hangar (not climatized) 100 miles from the coast
-came of Cessna 182 crash landing, engine quit during decent after para-drop.
-engine turns easily by hand
-cylinder walls are corroded
What i donít know:
-whether the engine was running or not on impact (shockloading?)
-exact engine designation
-history prior incident
-is there a market for this engine?
I donít have the paperwork.
What i plan on doing:
-check whether the crankshaft ist straight or not
-decide from result if rebuild is worth it or sell parts individually.
What would you do???
Click image for larger version
ID:	11610  Click image for larger version
RV-8 QB Germany
ECi XIO-360
Dynon SV
Flying since 11th July 2020
Old 05-15-2021, 08:05 AM
Flying Canuck Flying Canuck is offline
I'm not an engine guy at all, but it seems to me that the only red flag not listed is a prop strike. Not run, improperly stored, quit in flight last time it was run resulting in a crash landing, no logs, corrosion. Oh, and you have no history, so maybe you have the prop strike too. Sounds like a 425 pound paperweight/conversation piece.
Again, just the observation of a non expert.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Added GPS 175 and authorized for IFR April 1, 2021
Interactive map of all of my flights here
Old 05-15-2021, 09:07 AM
blaplante blaplante is offline
Default some value
It has some value as a core. How much I'm not sure. This https://backcountrypilot.org/forum/v...and-prop-16690 gave an estimate (5+ years ago) as $1000.
I would think if you were buying a new o-470 and providing this as the core you'd get more than $1000 --- assuming they don't open it up and find it is 100% junk.
RV6A in phase 2 as of April 2016
Donation made Oct 2020
Old 05-15-2021, 11:12 AM
Robin8er Robin8er is offline
I would tear it apart and send the part out for inspection. That inspection will let you know what to do next. Its either mostly trash, or you can rebuild it and have a quality engine. You can also sell the yellow tagged parts that pass inspection.
Edit- Just noticed you are in Germany. That might make it a little harder.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 05-15-2021, 04:12 PM
KayS KayS is offline
- disassemble
- check parts
- then decide what to do
Wo zum Henker hast Du das Teil jetzt her? Vom Flugzeugfriedhof geklaut?
Old 05-15-2021, 06:53 PM
moosepileit moosepileit is offline
Sell it to an airboat engine builder like Dick Waters as-is unless I wanted a project- then build it to sell to an airboater.
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Old 05-17-2021, 04:29 AM
fixnflyguy fixnflyguy is offline
Default P.Ponk conversion donor
Check with 182 Forums..P.Ponk conversion converts an 0-470 into a ******* engine with 520 cylinders and different crank requiring full tear down and case rework. (makes a 182 almost RV fast to keep it RV related).
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 05-17-2021, 04:52 AM
Dan 57's Avatar
Dan 57 Dan 57 is offline
Kay, I think your plan, as outlined above, is the correct one. On the other hand, a sale as is would for sure be possible in the US, using eBay or Barstormers as platform. Better check on the shipping costs beforehand...
Das wollte ich ja auch fragen, passt aber sicher auch in der -8 oder
Life's short... Enjoy!
http://www.aerofun.ch
RV-6.9 #25685, slider, O-360-A3A (carb/dual Lightspeed II), MTV-12-B, HB-YLL owner & lover
RV-4 #2062 HB-YVZ airframe builder
Old 05-17-2021, 08:10 AM
BoydBirchler BoydBirchler is offline
Dial the crank, pull the pan, take a look and take pictures of the cam and lifters. Sell it as a core for rebuild. Ought to be worth $3 to $5K. Prior log books are not important if you are using it as a trade in for a zero time factory engine.
Old 05-17-2021, 08:12 PM
pat76cj pat76cj is offline
if you were closer i would offer to buy from you.
seriously, you could offer it as a core for sale. based on what youve said, the only real useable parts are the case, crank, accessories. more rhan likely the cam and lifters are junk as well as the cylinders and pistons
