Go Back   VAF Forums > Model Specific > RV-6/6A
Old 05-09-2021, 01:30 PM
texdog texdog is offline
Smile Shimmy, not what you think
RV6A, very nice airplane that we have maintained and flew about 150 hrs. a year for the last 9 years. We have not had any problems but a main gear shimmy that seemed to go away except for 22 to 23 knots, no matter what tire pressure we used and we always balanced the tires. At the condition inspection last month we replaced the tire and tube on the left side. We just touched one of the four nuts holding the axle on with a wrench and it moved. They were lock nuts, but they were not tight. All four were about a quarter turn from proper torque. Four flights now and no shimmy at all, at any speed. CHECK THOSE NUTS.
T82 Fredericksburg,Tx.
Don't make easy hard!
Master Pilot Award
RV6A owner N6711
L19 sold
ATP/FE/CFI 10 Type Ratings.
Old 05-09-2021, 02:11 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I had a similar issue with the wheel pants brackets on the RV 10.
Due to the heat generated from braking action, that area should use all metal lock nuts IMHO.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-09-2021, 02:45 PM
Janekom's Avatar
Janekom Janekom is offline
I can only agree with that. I have also seen more than enough of those nuts loosening due to heat down there.
Jan Hanekom
South Africa
Approved Person nr 325
http://www.rvbits.com
RV10 - ZU-XOX - (Flying)
RV7A - ZU-JRV - (Flying)
RV10 - ZU-JVR - (Written off)
RV7 - ZU-LOL - (Flying)
RV10 - ZU-RVI - (Flying)
RV7A - ZU-MER (Bought back)
RV7A - ZU-JAD (Sold Flying)
Dues paid for 2021 WITH A SMILE
Old 05-09-2021, 09:13 PM
rvbuilder2002's Avatar
I don't usually go public with info prior to a design change being issued but will in this case because it is rather minor to describe.
The looseness is not because of heat on nylon lock nuts.
Yes, the brake disks do get hot but the disks are conductivity isolated quite a bit from the brake mount flanges. If it were a problem we would have seen serious issues by now with the airplanes that use bolts and nylon lock nuts to attach the axle to a flat gear leg.
The looseness is caused by the spacer bushings being made of 6061-T6 aluminum. It is just not a hard enough material to take the shaking / pounding of the wheel fairings. Over time the bushings suffer plastic deformation and reduce in length slightly. Once that happens, the bolts get loose and the wear process gets accelerated until the bolts are re-torqued.
A change is in the works to switch to steel bushings. The ones for the RV-10 will likely be all one piece in steel instead of the current steel reducer bushing and aluminum extension bushing.
Please don't call the office asking for the new parts. It will be a while until the change makes its way through the internal process. Once it has, they will then be available. In the mean time,it would be very simple for someone to substitute the same dimension steel tubing on a 6A, 7A, 8A, or 9A.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 05-10-2021, 05:06 AM
s24789 s24789 is offline
I saw the original post and the speed of 22-24 knots ground speed caught my eye. We had the exact same issue and after replacing many items replaced the right main tire and the world has been better ever since.
Kevin Phelps
Paid thru Dec 2021
RV-7A flying N782WP
Stuart, Fl
Old 05-10-2021, 02:19 PM
bjdecker's Avatar
bjdecker bjdecker is offline
Scott,
Thanks for the heads up; just to confirm we're all thinking about the same thing, I've attached a screen-grab of the plans -- you're referring to U-408, correct??
Thanks tons!
B
Click image for larger version
Name:	Screen Shot 2021-05-10 at 3.16.38 PM.jpg
Brian Decker
RV-7 (Flying)
Old 05-10-2021, 02:29 PM
jrs14855 jrs14855 is offline
Default Axle
As shown in the drawing in post 6 the bolts do not "hold the axle on" The axles on the round Wittman Landing gear are part of the machined one piece gear leg. The drawing shows the single bolt attaching the brake flange to the gear leg. The bolts described are used to attach the wheel pant bracket to the brake flange.
The RV8 uses the flat Wittman Gear and does have bolt on axles. Except for the 8, RV3 thru RV9 all use the round Wittman gear.
Wittman invented and patented the flat spring gear around 1935 and the round gear around 1950. That would be the Steve Wittman that Oshkosh Airport is named for.
Old 05-10-2021, 02:51 PM
bjdecker's Avatar
Thanks for the factoid...
The OP has an RV-6A, and I *think* he was referring to the 4 AN365-428A nuts that hold the U-403-PC to the U-810-L/R.
Scott was referring to the 3 bushings that stand-off the U-810-L/R from the U-403-PC.
Pics attached
Name:	Screen Shot 2021-05-10 at 3.44.28 PM.png
ID:	11411  Click image for larger version
Name:	Screen Shot 2021-05-10 at 3.48.23 PM.png
ID:	11412  Click image for larger version
Name:	Screen Shot 2021-05-10 at 3.48.56 PM.png
Brian Decker
RV-7 (Flying)
Old 05-10-2021, 04:28 PM
Default Bolts
OP clearly stated main gear.
Old 05-10-2021, 04:47 PM
bjdecker's Avatar
I don't understand.
Brian Decker
RV-7 (Flying)
