Old 05-04-2021, 05:47 PM
Wing nut Wing nut is offline
Default Primer inside a fuel tank!?
A friend bought older RV6 partially built kit. He recently completed one fuel tank and went to start the other and noticed the parts were all primed except the skins. Of course heís wondering why the heck he didnít notice it before building the first tank. It looks like it is the Sherwin Williams wash primer. His question to me was ďdo you think the primer in the tank is a problem?Ē Gosh I really donít know I said. Thatís a good question for this forum.
Heís ready to rip the first tank apart and re do it but would appreciate thoughts and input you may have. Thanks
Brett N
RV 8 flying since 2010
XP 360 with AFP FI
WW 200 prop
Old 05-04-2021, 07:42 PM
xkape xkape is offline
Chances are it's fine, but there's no way to know for sure. I have worked on many certified aircraft with primer on the inside of the fuel tanks that did nothing, but who knows what kind of primer the previous builder used.
What you could do is fill the tank partially with fuel and leave it for a few weeks to see what happens. Drain the fuel and if the fuel looks clean and the primer hasn't softened up, I wouldn't worry about it.
Old 05-04-2021, 08:42 PM
Taltruda Taltruda is offline
Is it possible that the ribs were Alodined? And itís not really primer at all?
Tom
Las Vegas
RV-4 flyingÖ
RV-8 empenage finished 10-2020
Wings Started.. 11-2020
Old 05-04-2021, 08:59 PM
JDeanda JDeanda is offline
Default Slosh?
Iíve seen a pair of tanks that had sloshing compound that looked like zinc chromate. It felt a bit soft under a thumbnail, not a all like chromate primer. Not that sloshing is a great idea, but at least itís not primer. Iíd go with xcapeís idea of putting fuel in and seeing what happens. BTW, there is an old Vans Service Bulletin about sloshing compound bubbling and separating from the insides of fuel tanks. (and thatís what was happening to the afore mentioned tanks) Even if itís doing that, all is not lost. Weep No More can still save the tank... for a price.
Old 05-04-2021, 09:14 PM
I asked him this exact question and he can remove the primer from the ribs on the other tank parts.
Brett N
XP 360 with AFP FI
WW 200 prop
Old 05-04-2021, 09:51 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Vans sell a fuel tank repair kit which allows round access holes to be cut in the rear baffle so as to get inside the tank without major disassembly, then patched. This may be an option for cleaning off the primer in the completed tank, if that is what your friends decides to do.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 05-06-2021, 08:47 AM
Thanks guys. Iíll pass this on.
Brett N
XP 360 with AFP FI
WW 200 prop
Old 05-06-2021, 07:27 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
If it is good epoxy primer it is OK. What is less desirable is the slosh compound that was recommended back in the day by Van's. It is a tank sealant, long been out of favor. It was white. Primer, if quality epoxy primer it will be fine with Av gas. Even if a little dissolves it it not going to cause an issue. If it was poorly done and flakes off then that might bock to filter. Monitor to fuel filters.
There is no PHOTO... so this is a qualified answer and you accept all risk. (Disclaimer required by my lawyer at Dewey Cheatem and Howe. Cheers)
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2021 Dues Paid
Old 05-06-2021, 08:00 PM
wirejock's Avatar
wirejock wirejock is offline
Default P60G2
Probably no help but I have learned to keep Alumiprep far away from SW P60G2. Peels the stuff off like paint remover. Not sure why but I think it's some sort of chemical reaction.
Just an idea if it is SW Wash Primer P60G2.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 05-08-2021, 08:23 PM
Pilot8 Pilot8 is offline
No way I'd fly with tanks like that! The aluminum is aggressively roughened for tooth adhesion, cleaned with acetone to remove oils that improves adhesion, then liberally lathered with proseal for sealing and adhesion. Primer is an unwanted and undesirable feature to add to the stackup- off label as they say. I usually answer questions about doing tough jobs by asking myself: "When the tanks start leaking in the future, what would I have been willing to do now?". Buy the proseal remover at Aircraft Spruce , drill out the rivets, clean everything up, and do the job right- you'll feel much better when it's done.
Sam Ray
fastback RV8
