Old 05-04-2021, 04:33 PM
David Z David Z is online now
Default Rear Seat Throttle Parts
I have the deluxe DJM throttle quadrants from Flyboy Accessories. Both front and rear quadrants. Problem now is I'm trying to figure out how to install it into the fuselage as it's being built. I did not get the Van's rear seat throttle kit as I wanted the nicer DJM throttles. Looking at other builders logs, there's several parts I'm missing. The clevis and pins are easy. The pushrod and side plate are much harder to figure out. The drawing from Van's, DWG OP-2 is also easy to order. I'm really hoping to avoid ordering the whole rear seat throttle kit, just to toss half of it in the trash.
From what I can tell, I need to order the side plate, pushrod and drawing from Van's. I'm hoping someone is able to give me part numbers so I order the correct pieces. Please, if there's anything else I'm missing, or other suggestions let me know.
Click image for larger version
RV8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage at the "porcupine stage"
83126
Dash 8 day job is financing the RV8
Donation till September 2022
Old 05-04-2021, 04:42 PM
Nihon_Ni's Avatar
Nihon_Ni Nihon_Ni is offline
Here's OP2, this should help.
Name:	OP02 RV-8-8A Rear Seat Throttle.pdf
Rob K
RV-8 N884RA under construction
Old 05-04-2021, 05:18 PM
That's fantastic! Should be able to find everything I need. Thanks
RV8
Wings mostly done
83126
Old 05-04-2021, 07:40 PM
csdominey csdominey is offline
I just finished this in a fuse project with the armrest already installed. Had to drill out that armrest piece to get access to the pushrod/lever connections, reattached with #6 screws and nutplates to allow the multiple trial fittings. Be careful to fit the mounting plate under the armrest (sec EE on the plan). I remade that mistake, and had endless issues fitting the pushrod through the bulkheads. Had to patch in new plate to correct all that. Best approach I found was to attach the forward throttle clevis on the bench, then pass the pushrod up from the rear to connect into the clevis.
After doing it about a thousand times, it finally makes sense.
C Dominey
Alvin, Tex
N977CD reserved
Name:	Rear Throttle Armrest connections.jpg
